PassionFord - Ford Focus, Escort & RS Forum Discussion (https://passionford.com/forum/index.php)
-   Technical help Q & A (https://passionford.com/forum/technical-help-q-and-a-14/)
-   -   help! ford Techs! It's driving me crazy. (https://passionford.com/forum/technical-help-q-and-a/440112-help-ford-techs-its-driving-me-crazy.html)
foci Oct 29, 2012 09:58 AM
My Chime for 'lights left on' isn't working!
It's a 2009 Ford Cmax Diesel. I keep leaving my lights on because of it.
The chime works if you don't have your searbelt on ETC. It's Set correctly in the dashboard menu. I just can't seem to get it to work.
Is there any ford techies that have seen this problem before?
Any info would be appriciated
Thanks
Karl 3dr Oct 29, 2012 10:29 AM
Its more than like the door ajar switch playing up, not sure if they have a separate one or if its built into the door latch though.
foci Oct 29, 2012 11:35 AM
The interior light illuminates/goes out when door is open/closed so should that not eliminate the switch?
Zippy_st Oct 29, 2012 06:43 PM
Had this on a focus, the chime never worked, it required a reprogram of the instrument cluster. If the chime did work, and now stopped, it may be something else
© 2026 MH Sub I, LLC dba Internet Brands
