zvh turbo cossie management help needed
hi everyone .. i really need some advice .. Basicly i have a 2.1 zvh turbo and ive
just finished fitting cossie L6 management running wasted spark setup the management came off a zvh before i bought it ...when i finished fitting everything to it i tried starting it but had no spark ,so i fitted a new crank sensor,stil no spark so i checked everything related and it was the coil pack that was faulty and phase sensor .so i changed them now the spark is spot on..
Problem i have now is when i try and start the engine it trys to start but catches slightly then cuts out it smells very rich and sounds as if its only firing on maybe 2 cylinders... ive checked everything i can think of ie power to all sensors/injectors compression test was fine re checked timing only visualy ,
checked all vacume pipes etc played around with the fuel pressure regulater ...Stil no differance ... please help
hi mate i think so with engine at tdc on the the crank ive got 1 of the 4 pickup lugs in line with my cps ..on the cam pulley stil at tdc ive got the pickup lug set at approx 40 degrees btdc the phase sensor is dead inline with my tdc mark on the cam as it bolted on a custom bracket to the rocker cover .. i do have a piper cam thou not sure if it affects it ??
kosienutter
31
22-08-2015 09:55 AM
Cameron
14
09-08-2015 06:28 AM
