P1666 fault code 55 transit connect.
Old Dec 23, 2011 | 12:31 PM
KaTurbo's Avatar
KaTurbo
Default P1666 fault code 55 transit connect.
With an endura di engine. Keep getting p1666 and p1000, had a search on here but only 1 thread came up. Where should i be looking to solve this? Had the crank sensor out and it 'looks' fine.
Van is only occasionally starting but cutting out right away most times. Other times it will rev up but the therevs jump about an it dies.
Any suggestions? Cheers.
Old Dec 23, 2011 | 12:39 PM
GVK.'s Avatar
GVK.
P1666 iirc is a syncronization timing error,can be caused by faulty cam sensor on top of rocker cover. (if TDCI)
Ford modified them, and a good tip is to put a 12v ignition feed to the pin that is the 5v reference on the sensor, gives a better signal.
I think the modified sensor is grey and original is black, 90% sure on that. Long time since I fitted one.
sensor on eBay - http://www.ebay.co.uk/itm/ford-FOCUS...item1c15c538d5
Old Dec 23, 2011 | 12:42 PM
GVK.'s Avatar
GVK.
p1000 is nothing to worry about, it just means that the OBD drive cycles or 'readiness' hasn't been carried out after clearing DTCs/disconnecting battery etc.
Old Dec 23, 2011 | 12:51 PM
KaTurbo's Avatar
KaTurbo
Cheers fella. Had a quick lool and cant see a cam sensor on the rocker cover though.
Old Dec 23, 2011 | 12:57 PM
GVK.'s Avatar
GVK.
Oh........I thought a 55 plate would have one, weird! does it have any TDCI badges anywhere
Noticed you said endura di, but I thought it'd be too new for that.
Old Dec 23, 2011 | 01:06 PM
KaTurbo's Avatar
KaTurbo
No mate, no tdci badges.
I did a timing belt on a 55 focus a few weeks back that had the endura diesel engine in it aswell, ford must have been trying to get rid of the last few eh!
Any other ideas fella?
Old Dec 23, 2011 | 01:07 PM
GVK.'s Avatar
GVK.
This is a TDCI Connect, you can see the sensor next to the blue bit in the centre of the rocker cover.
Old Dec 23, 2011 | 01:10 PM
GVK.'s Avatar
GVK.
If it hasn't got a cam sensor, the timing error could possibly be a timing fault (cam belt) or crank to pump timing chain fault or something along those lines.
When you had the crank sensor out, did it look ok with no swarf or marks on it?
Could try a crank sensor and check the timing.
Old Dec 23, 2011 | 01:37 PM
KaTurbo's Avatar
KaTurbo
No cam sensor mate, tried a crank sensor and it dies right away.
Old Dec 23, 2011 | 02:03 PM
GVK.'s Avatar
GVK.
Have you tried running it on easy start?
If it will start on easy start chances are the timing is ok, if not you've got to look at a fuelling error.
Old Dec 23, 2011 | 03:37 PM
KaTurbo's Avatar
KaTurbo
Ran on easy start fella, and the idled itself. As soon as you rev past 3.5k it dies though and wont start. Fuel pump?
Old Dec 23, 2011 | 04:29 PM
GVK.'s Avatar
GVK.
Looking like fuel pump, but as the code is a fuel pump syncronisation error (timing) I wouldn't jump to conclusions - one of the lads I worked with did a big engine job on a Connect once (oil leak behind the front cover)
When he built it back up it wouldn't start, after a lot (days of messing about) it turned out he had used the wrong crank pin to time it up!
If it was a Transit 2.0 / 2.4 with a P1666 that can be caused by a timing chain fault.
Old Jan 6, 2012 | 05:58 PM
KaTurbo's Avatar
KaTurbo
Just to let you know fella, took a chance and changed the fuel filter, all seems to be ok!
Thanks for your help fella.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
Neil Clark
21
Oct 1, 2015 07:02 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Si B
Sep 12, 2015 06:49 AM
