sorry not a ford but my audi problem
Old Aug 7, 2011 | 02:13 PM
gazdon's Avatar
gazdon
wheeler dealer
Default sorry not a ford but my audi problem
hi peps sorry not a ford but a 1998 audi A6 2.8 problem it drives ok but when i move the accelerator up and down you can see and feel the gearstick move judder itis also grinds if you put it into 1st gear when the car is just moving very slightley could this be a worn engine or gearbox mount.
Old Aug 7, 2011 | 02:41 PM
botters's Avatar
botters
competant bodger
possibly yes
Old Aug 7, 2011 | 03:20 PM
gouch1's Avatar
gouch1
id say box mount
Old Aug 7, 2011 | 03:30 PM
cabriolet's Avatar
cabriolet
dog bone under gearbox
Old Aug 7, 2011 | 04:11 PM
warrior within's Avatar
warrior within
I say throttle body lever... check this first is easier
Old Aug 7, 2011 | 05:32 PM
gazdon's Avatar
gazdon
wheeler dealer
throttle body lever i know were itis but what am i looking for regards gaz
Old Aug 7, 2011 | 05:42 PM
warrior within
check the lever, you remove the debimeter and the airbox and see if pulling the ironwire of the accelerator manually (not on the car but with ur hands) giving a look to the throttle it opens smoothly or if it has some problems like delay... that could be caused by the hub that should be upper...
Old Aug 7, 2011 | 05:43 PM
foxy06's Avatar
foxy06
The 2.8 boxes have a common problem with first gear wheel, chips usually and casues a grinding in first gear only. Will drive like this still for a while thou, then rebuild or replace.
The snub mount is also best to upgrade for the movement, but check all mounts also.
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Dr. Ickxs
Aug 15, 2015 11:34 AM
M K
Aug 12, 2015 06:57 PM
