ford granada cosworth indicator problem
Old Feb 7, 2011 | 08:49 PM
cardifftwilite1's Avatar
cardifftwilite1
Post ford granada cosworth indicator problem
hi, i have a Lreg grany, which im having problems with, the indicators, wont work, ive put a new stalk on, a new relay,which is on the stalk itself. hazards work fine, im at a loss, as to wot to try next?
Any help would be great!!!
thanks
Old Feb 8, 2011 | 07:26 AM
The fact that the hazzards work show the circuit is ok to the indicators, the power goes from a live source that is ignition switched to the indicator unit, so check there is a live at the indicator unit, this then goes out the indicator unit to the stalk, where it stops, as it is a dead end circuit, unless the stalk is put to left or right, where current will flow to the lights on that side, this causes a bi metallic strip to heat up, as it passes the current, it gets hot and bends away from the contact so breaking the circuit, it cools bends back and touches the contact again, passes current and the lights are on again.
This is how you get the on off, so check for power at the indicator relay from ignition then power out etc.
Old Feb 8, 2011 | 07:43 AM
dojj's Avatar
dojj
Resident Wrestling Legend
the hazzard lights work on the flasher relay
you will find that the most likely problem is the fuse for the indicators or the fuse box itself getting wet
Old Feb 8, 2011 | 08:29 AM
cardifftwilite1
Post indicator probs
hi, thanks for reply, ive checked the fuses, as far as i can see they are all fine in both fuse boxes, although im 100% sure as to which the correct fuse is, as i dont have the manual!!!!
thanks
Old Feb 8, 2011 | 08:47 AM
dojj's Avatar
dojj
the insides of the covers will tell you
change them anyway as i had a dodgy fuse once that no end of problem solving didn't turn up until we pulled it apart and you could see that there was a small crack in the joint so it was hit and miss it it worked or not
Old Feb 8, 2011 | 09:05 AM
cardifftwilite1
hi again, all the covers have on them are the fuse numbers!!!!!
thanks
Old Feb 8, 2011 | 09:51 AM
dojj's Avatar
dojj
fuse 27 on the drivers side and fuse 45 on the passenger side is all that i can find as there doesn't seem to be a seperate feed for them, unless you can deciper connection C and E in the central fuse board which is what seems to feed the indicators
Old Feb 8, 2011 | 02:08 PM
cardifftwilite1
Post
ok, thanks for advice, will change the fuses and c wot happen`s
thanks again
will let you no of the outcome
dodge8283
27
Aug 19, 2015 08:42 AM
Aug 14, 2015 07:29 AM
RIB1122
Aug 12, 2015 08:51 PM
dlwarrior
Aug 5, 2015 10:19 AM
