PassionFord - Ford Focus, Escort & RS Forum Discussion (https://passionford.com/forum/index.php)
-   Technical help Q & A (https://passionford.com/forum/technical-help-q-and-a-14/)
-   -   ERST ecu's chipped? (https://passionford.com/forum/technical-help-q-and-a/363667-erst-ecus-chipped.html)
rambo84 Aug 17, 2010 09:06 AM
ERST ecu's chipped?
do both ecu's need to be chipped on a rs turbo or is it just the boost ecu that needs to be chipped?
chaffe Aug 17, 2010 10:38 AM
i just had my timing "silver" ecu chipped on mine, and thats all i had heard of until recently, but a mate on here, 155lee, has had both of his chipped, not sure if this is necesary as the fuel ecu will work with more boost, mine did.
rambo84 Aug 17, 2010 03:51 PM
thats what i thought but i have a superchips chip on my s2 and the fuel ecu has a sticker on it aswell, and i had a few running problems and turns out to be my fuel ecu that was causing it and now i have fitted another standard fuel ecu it doesnt seem to run right on full boost
JamesyRS Aug 17, 2010 04:09 PM
had this discussion with my tuner before your meant to have both chipped to get full benefit of them
rambo84 Aug 17, 2010 06:38 PM
so what do they do to the fuel ecu? i have looked at the boost ecu and you can see where they put the chip in, but the fuel ecu has no signs of any work been done to it?
© 2026 MH Sub I, LLC dba Internet Brands
