fuel pipe
what fuel pipe should i use for inside a fuel tank as it will be submersed in fuel aswell as being used for fuel.
u can buy propper fuel hose from any good motor factors . they do a low pressure rubber and a high pressure overbraided rubber . although i assume it's only a pick up i would try and get some high pressure pipe . cheers Ally
You can use any fuel resistant pipe, for inside or outside, I use OPA, as resistant to all oils petrol/diesel.
tabetha |
© 2024 MH Sub I, LLC dba Internet Brands
