2wd cos speedo worm drive cog/gear
Can you still buy the gear bit new or is it obsolete now?! After spending ages messing about with the cable thinking it was that i ended up sticking it in gear and had the arse in the air and looked at the worm drive casing the cable pushes into and thats not spinning, so guessing the gears are now worn too much?! the gearbox was a recon one in the car so assuming its not an internal prob with the box......
Tony
Tony
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
03-11-2015 04:08 PM
