hi jsut got a 2.0l twin cam 2000e auto but im looking to change it to manual and was wondering if any one has done it on here before or knows whats bits are needed to do this ?
To do it you need a manual twin cam sump, flywheel and starter plus whatever box you want to fit, you would really want a mt75 as these are easy enough to get hold of plus the relevent prop shaft and a pedal box. Hope this helps
The manual sump is cutaway around the starter mounting possition but the auto one is cutaway on the opposite side and sticks out where the starter would sit on the manual MT75 or type 9 box.
Hope this helps
