brake master cylinder
im going to take the abs off soon and the master cylinder has 2 brake lines running from it could i still use this master cylinder to run front brakes and back brakes from it and t-piece it im going to use a bias valve aswell
So long as the holes in the master cyl allow suffecient pressure through them, some are a different size to suit front rear.
tabetha |
© 2024 MH Sub I, LLC dba Internet Brands
