EST Fuel Pressure's???
One for the techs/tuners.
Any one any idea what the fuel pressures should be at various stages of the ERSTs fuel system? Operating pressure? Supply pressure? System pressure? Cold control pressure? Warm control pressure? Injector opening pressure? Return line pressure? Any help much appreciated :top: |
THIS MAY HELP ;)
PRIMARY FUEL SYSTEM PRESSURE 5.65-6 BAR FUEL DELIVERY 1100 CM3 / MINUTE MINIMUM LOWER CHAMBER PRESSURE PRIMARY PRESSURE--- LOWER CHAMBER PRESSURE 5.65 BAR------------------5.35 BAR 5.7 BAR--------------------5.4 BAR 5.8 BAR--------------------5.5 BAR 5.9 BAR--------------------5.6 BAR 6.0 BAR--------------------5.7 BAR FUEL SYSTEM LEAK TEST MINIMUM AFTER 20 MINUTES 2.6 BAR INJECTOR OPENING PRESSURE 3 TO 4.1 BAR |
Does help indeed, top man cheers :clap: :top: :clap:
| All times are GMT. The time now is 08:54 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
