P8 "baby" board
Old May 30, 2009 | 01:08 AM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
Default P8 "baby" board
Having got the car checked over at turbosystems im now left with a dilema as what to do with my ECU.
As it stands i have a early collins copy of a pectel board but not sure which version it is. From what i understand some of the very early stuff collins popped out had serious flaws and it depends which version of firmware you have. So obviously i want to identify the board to work out wether to junk it or keep it!!
I know my chip has to go as its a terry drury chip which is a rallycross map for a restricted rally engine using air injectors - and my car has no restrictor and is a road car
To aid identification i pulled ECU out car for a nosey (cars broken ).
Removing the cover:
WTF bits of foam!!
Under the foam there is yellow tape:
And under the tape you can see the chip. note theres no manufacturer sticker etc like other tuners do to identify the product! As i understand it, the red paint is what terry drury did on his products?!?
Nothing under the board to help me either:
It does have "P8" written on it in two places but thats it.
Also on the main ECU circuit board there are these big blobs of white stuff:
What the hell is going on with that??
so anyone know which kind of pectel board copy it is?? Will collins themselves be able to identify it???
Old May 30, 2009 | 09:03 AM
I'm sure Collins would be able to identify it, surely your best 1st bet ?
Old May 30, 2009 | 04:55 PM
t4 and greys's Avatar
t4 and greys
cosworth gimp
wow looks like you have a small fried egg inside your ecu
acyually that stuff is usually used to protect capacitors and the like from being damaged/pressed onto circuit board and shorting ..
still looks like an egg tho
Old May 30, 2009 | 10:00 PM
costina's Avatar
costina
Live long and prosper!!
I'd bin that old board and buy a new chip from Stu depending what spec your running
oh you won't need a board with his either
Paul
Old May 30, 2009 | 10:22 PM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
take the bottom cover off of the ecu, those components with the white paste on might have been repaired....you will be able to tell from the solder underneath if they have been reworked at some point.
I say this as the paste looks to have been applied after the ecu was assembled...small bits on teh clip between the blobs. Plus i've never seen this on any cossie ecu i've opened up before.
Dan
Old May 31, 2009 | 01:54 AM
Psycho Warren
Carbon Crazy
so where does the chip plug in if theres no baby board of any kind???
Old May 31, 2009 | 10:45 AM
costina's Avatar
costina
In the socket which is left once you have removed baby board
Paul
Old May 31, 2009 | 10:46 AM
costina's Avatar
costina
Dan
White blobs of goo are normal on a P8
Paul
Old May 31, 2009 | 11:14 AM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Costina is right with everything he's said so far
Our chips do away with the baby boards and go straight into the motherboard and the white goo is present in P8s from the factory.
Might be of interest to you Warren, we've been doing some development on P8 Launch Control as well as ALS!
Old May 31, 2009 | 11:20 AM
costina's Avatar
costina
Thanks Will as you know i've been in a few lol
Paul
Old May 31, 2009 | 11:00 PM
Psycho Warren
Carbon Crazy
cool!!
I know about ALS etc as ive spoken to stu about sorting a chip out late last year, just had serious financial issues since with jobs that didnt materialise and breakdowns now ive got job and car running
Probably going to have to buy a basic chip then upgrade from there as i save money. annoying really!!
had a good look at the P8 circuit board last night and it hasnt been repaired in any obvious way near the goo!!
Was the P8 circuit board used in other cars/had later revisions???
I notice theres a lot of unused componant pads and tracks on the circuit board:
Also what used/is here on other same generation ECU's?? some kind of adjustment screw judging by hole??
Old Jun 1, 2009 | 11:00 AM
Bomber's Avatar
Bomber
My P8 has the adjustment screw. Some came with, some came without.
Old Jun 1, 2009 | 03:39 PM
Psycho Warren
Carbon Crazy
adjustment for what?
Old Jun 1, 2009 | 06:00 PM
SillyFezzaMk1
Rubber Rhino Crew
Paul
O'Rly....Learn something new every day, I've been inside an old P8 Ihad years ago and never noticed any globs like that, maybe it wasnt a P8?? Or maybe I just didnt notice it (more likely) LOL
Good advice coming ont his thread
Dan
Old Jun 1, 2009 | 07:29 PM
costina's Avatar
costina
co trim screw
i could be wrong but some lancias came with a weber marelli ecu
Paul
Old Jun 1, 2009 | 08:18 PM
Bomber's Avatar
Bomber
co trim adjuster.
DixieTheKid
11
Jun 6, 2020 11:20 AM
DAN@ADRIAN FLUX
Insurance
15
Jun 30, 2018 09:00 PM
hopper350
Sep 4, 2015 12:53 AM
Escortdriver1
Aug 19, 2015 09:02 PM
