Zetec help needed PLZ
Old Mar 23, 2009 | 06:25 PM
Rs Cosworth 1's Avatar
Rs Cosworth 1
RS for life
Exclamation Zetec help needed PLZ
Right i have a 1.8 ZETEC black top,
Now the oil pump went on me a few year's ago so had it rebuilt STG 2 head fast road cam's etc,
Now i did a compression as the HP didn't feel there it rev's up perfectly not a stuter anything spot on,
But the compression test brought back a result of 70psi per cylinder?
Now i heard the com[ression is supposed to be around 120-130 mark per cylinder.
I have been told to check my valve's in case there stuck but how would i go about that without removing the head?
Anyone got any idea's i mean the egine is spot on just rev's quite slow IMO pull's up the rev range no problem just doesn't feel like there is any force in the engine!
HELP PLEASE
Old Mar 24, 2009 | 10:22 AM
Rs Cosworth 1
RS for life
Anyone please????????????????????????????
Old Mar 24, 2009 | 02:57 PM
scotty86d's Avatar
scotty86d
did you open the throttle as you did the comp test. is your battery good and starter working fine?
timing could be well out.
Old Mar 24, 2009 | 05:21 PM
Rs Cosworth 1
RS for life
Hi mate thank's for the reply
Yeah throttle was open battery is fine m8 starter is fine too
The belt was just done at ford so timing should be ok
Just lack of power it drive's ok just no real power in the car u know
Old Mar 24, 2009 | 05:38 PM
scotty86d's Avatar
scotty86d
right, do the comp test again and put a little bit of oil down the bore then fit the tester. if the compression goes up then ur rings are a gonner and if it stays the same then its head gasket i think
also do a coolant test. kit for it is about a tenner. the colour determines if exhaust gasses are getting into your coolant. try burtons or a motor factors for it
Old Mar 24, 2009 | 07:02 PM
Rs Cosworth 1
RS for life
Wow man thank's for that,
I will do but now u mention my header tank is near black water what's that mean???
I will empty it asap but it is blackish water,
CheeRS dude thank's
Old Mar 24, 2009 | 07:42 PM
scotty86d's Avatar
scotty86d
erm, empty it out and put fresh coolant. run the car for a bit then do the coolant test i reckon.
Old Mar 25, 2009 | 12:55 AM
Rs Cosworth 1
RS for life
Thank's dude will do cheeRS
JoeyBoyden
Jan 4, 2024 02:36 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
coozer
Ford Focus Range
Aug 15, 2015 10:26 PM
Rickyrustyfox
Aug 13, 2015 01:11 PM
col93saphcos
Aug 7, 2015 03:21 PM
