power steering pump cossy will it fit ?
Old Feb 11, 2009 | 10:48 PM
neo's Avatar
neo
Default power steering pump cossy will it fit ?
Daft question guys, my mother has a 1975 cortina mk3 which she has owned from new, and aint using it anymore as she is 62 and the steering is too heavy for her, so i want to fit power steering to it if i can, my question is this..
It has a single OHC pinto 1.6 sierra engine in now and will any of the cossy 2wd or 4wd pumps mount to the engine near the distributor, are the pinto blocks the same as the cossy block castings ?
My idea is to use a cossy pump,resovior,pipes and a cortina power rack, the reason i am not using cortina power steering pump as only the V6 mk4/5 had PAS so different mounts etc....
any idea's
then i will need the bits including a crank pulley with double V groove...
Old Feb 12, 2009 | 03:55 PM
2wd cossie pump will go straight on, you don't need a double pulley either, just measure and get a longer single belt to go round all the pulleys, might work ?, worth a go first ?
Old Feb 12, 2009 | 10:03 PM
neo's Avatar
neo
cool thanks, i am correct in thinking its mounted on the inlet side if it is i will need the double pulley as it wont grip the crank pulley if it goes both ways good idea though...
just need to find one for sale now complete
Old Feb 13, 2009 | 11:07 AM
Yes on inlet side on cossies, ie on nearside of car.
kosienutter
31
Aug 22, 2015 09:55 AM
RockinRein
Aug 19, 2015 07:08 PM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
Gadget
Ford Escort RS Cosworth
Aug 13, 2015 06:43 AM
track.focus'd
Aug 12, 2015 05:53 PM
