Wiring Loom
Where can I get a range of automotive cable in various colours/ampage, and also the black seathing that a lot of people are using (can't remember the name of the stuff for the life of me) and various connecters.
I need to redo the wiring the saph as basically the current loom is pretty fubared so while is off the road I'm going to sort it out. |
Try for some shrink wrap from cromwells or RS componants. That should do the trick :D
PICK UP THE CORRECT AMPAGE of cable and add it in the the circuit. You might not find the correct cable marking but most fords dont have the factory markings as it goes lol |
Try polevolt.co.uk
Failing that I can supply everything(including a loom) built by a pro, this can be in the BRAID to which you are reffering, or the better abrasion resistant heat shrink, as I have. NB decent aftermarket looms normally use either 44 or 52 wire, these are aircraft grade wire, and it is roughly TEN times the price per metre of std wire. I also have all the markers to go on the cables, can do one offs, can even have one fitted on your car as a one off no problem. All/any mods catered for as well. tabetha |
© 2024 MH Sub I, LLC dba Internet Brands
