driveshaft compatibility
Old Aug 11, 2008 | 04:41 PM
stuy's Avatar
stuy
Default driveshaft compatibility
this is an easy one i need to replace an n reg escort cosworth nearside driveshaft i can only get new sierra ones, are the 4x4 ones the same as the escort for a direct replacment, thanks for your help in advance.
Old Aug 11, 2008 | 04:57 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
i dont think they are but dont take my word for it
Old Aug 12, 2008 | 05:54 PM
cossytel's Avatar
cossytel
You dont say wether its front or rear shaft. however the rear shafts are all same except rwd sierra cos which use bigger cv joints and thicker shafts, i assume its probably front as these usually give trouble. the escos and sierra cos4x4 are same but v6 sierra 4x4 use longer shaft (10mm) but same joints, however many people use longer shaft especially on very low cars as the increased angle on the shaft as the suspension is loaded can cause damage to joints and even pull apart completely especially if the engine mounts are tired. check the engine mounts before replacing or you could be replacing again very quickly.
Old Aug 12, 2008 | 06:06 PM
peachy's Avatar
peachy
What he said lol
You can still buy them from dingbros. My mate canged his but it pulled apart so he claimed warrenty! Since then its been fine tho.
Old Aug 13, 2008 | 03:42 PM
stuy's Avatar
stuy
thanks for that cossytel it was the front yeah nside il look into the mounts as the car isnt that low but is on 19s could that be a problem?
Old Aug 13, 2008 | 05:41 PM
peachy's Avatar
peachy
It changes the angle in which the drive shaft lies because of the camber on the wheels, tight corners or hard bumps can pull the CV joint apart. Or in my mates case, the rolling road when they strapped it down!!! He still made 283@wheels tho
Old Aug 13, 2008 | 09:00 PM
cossytel's Avatar
cossytel
The 19s shouldnt be a problem, while your under there though it might be worth a quick look at inner tca bushes, if they are tired they can add to the problem, if they are rubber i would consider some polyurethane ones.
mondeomark
Sep 28, 2015 06:28 AM
rsturbo27
Sep 5, 2015 05:08 PM
jonjg
Sep 1, 2015 03:46 PM
Mark Mawson
Aug 31, 2015 07:09 PM
markk
18
Aug 17, 2015 05:19 AM
