Fitting RS500 Style cooler in Escort
I’ve just bought a Pro Alloy radiator and RS500 intercooler style for my Big Turbo Escort Cosworth. The question is when the old charge cooler is removed, what do I do with the two water pipes running to the charge cooler? I assume I just route it from the water pump side to the heater matrix side. If this is true, is there a specially formed hose for this application that I can buy? It looks like quite a tight bend.
Thanks John |
would also like to no this
After speaking to Pro Alloy, they supply a 180 degree pipe which is designed to full fill this purpose. Got one on order and should arrive today.
© 2024 MH Sub I, LLC dba Internet Brands
