Electric windows in an Escort Van
Old Dec 20, 2007 | 10:45 PM
LSI's Avatar
LSI
Default Electric windows in an Escort Van
Alright chaps, I come back from the dark side lmao
Right, got my mate with this here Mk5 Escort van, usual poverty spec, but he spends alot of time in it and wants electric windows because he pulls alot and his wrist hurts.
So, here's me breaking an LX with electric windows, chance for a job here eh.
Comparing the two, it's unfortunatly not a case of transferring the regulators and loom and plugging them into the bulkhead connectors, because on the van they aren't there, there's no twist plug on the bulkhead, just some wires, presumably just the speaker feeds as it's not got central locking.
The mechanism looks fine, drilled the rivets out, and had to drill out the cross head screws holding the mech to the window runner because they were tight on and I was just taking the head off the screws (I'll replace them with nut & bolt I think?) also got a rivet punch for popping the regulators and motors back in.
Feeding the door loom through the hole looks tricky but doable with some patience, but just wondering what the loom layout should be inside the car itself to add electric windows to this van that obviously has no wiring for them.
As I say, I was hoping the wiring would be there, just redundant, but alas there's nothing. Obviously I have the switches and everything, I have the whole donor car.
Would the dash need to come out to feed the loom into the bulkhead hole, or would I just get by undoing it on the side and giggling a little for luck?
Many thanks chaps
Matt (Still with the Cav lol!!)
Old Dec 21, 2007 | 06:15 AM
If you have the loom with the windows it is just a case of a live and earth to add to the switch panel.
Old Dec 21, 2007 | 08:36 AM
LSI's Avatar
LSI
Simple as that is it? All fused up already, so to speak.
I do indeed have the whole loom for it, yes.
Old Dec 21, 2007 | 08:59 AM
gkandr4ch's Avatar
gkandr4ch
I've just done this conversion on my MK6 van.
I have PM'd you.
Old Dec 21, 2007 | 09:13 AM
LSI's Avatar
LSI
Appreciated Greg, thanks. I'll give you a bell if I get into difficulties with it, but I'm somewhat mute at the moment *fecking chest infection)
Old Dec 21, 2007 | 10:21 AM
gkandr4ch's Avatar
gkandr4ch
You are not the only one who is ill.
Old Dec 21, 2007 | 11:06 AM
Alvyn's Avatar
Alvyn
sorry for jumping on your post
can you also pm what's needed to me as may well attempt this on my next mk6 van if it comes without!
FlashRS
Sep 14, 2015 12:36 PM
Mxkid
Aug 31, 2015 10:02 PM
gordyshreds
20
Aug 10, 2015 02:59 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
jimmy oldskool
Aug 4, 2015 07:06 AM
