PassionFord - Ford Focus, Escort & RS Forum Discussion (https://passionford.com/forum/index.php)
-   Technical help Q & A (https://passionford.com/forum/technical-help-q-and-a-14/)
-   -   mk5 escort 1.8 zetec won't start. (https://passionford.com/forum/technical-help-q-and-a/214546-mk5-escort-1-8-zetec-wont-start.html)
Graham S1 Nov 30, 2007 01:27 PM
:( 1st time since april it's let me down.
got fuel to rail (can hear pump as well), got good spark. what next? ecu borked? turns over, won't catch. although it did catch a couple of times when it was being looked at by recovery guy last night, but died after 20 seconds. Also started when I tried it today 1st time, but died after about 5 secs. :?
Help please. :D :banana:
Wardy257 Nov 30, 2007 06:22 PM
ECUs rarely break. Have you got injector switching? How did you check you have spark?
Graham S1 Dec 1, 2007 08:40 AM
think the recovery guy did it by getting the plug out and leaning it on something. I was in the car turning it over.
what makes the injectors switch, and how can I test it?
Wardy257 Dec 1, 2007 05:12 PM
Use a Bosch 2 pin NOID light or an LED test light. Crank the engine and the light should flash.
Graham S1 Dec 2, 2007 01:59 PM
across the injector contacts?
(cheers by the way :top: )
Graham S1 Dec 4, 2007 11:28 AM
should I be able to hear injectors clicking when turning over?
should I be able to blow into the fuel reg?
anyone?
© 2026 MH Sub I, LLC dba Internet Brands
