Quick question- OHC under the rocker cover
Old Aug 12, 2007 | 12:17 PM
vibrating_cake's Avatar
vibrating_cake
Default Quick question- OHC under the rocker cover
Is there suppost to be a pool of oil under the rocker cover around the springs?? like in my pics, and is everything normal here .
Old Aug 12, 2007 | 04:03 PM
That looks perfectly normal, it's when you don't have any oil there you need to worry as the spray bars can get blocked if oil changes are neglected!!
Old Aug 12, 2007 | 04:50 PM
Aaroncast's Avatar
Aaroncast
correct as tab says-also available is a better spray bar for h/performance applications.prone to not getting enough oil to the front !!or was it the back???
Old Aug 12, 2007 | 05:13 PM
I think it was any hole as the feed is from the centre outwards, there is a bar you can get with a tiny filter built in from, I think burtons ?
I always use FLUSH prior to any oil change so never had a problem.
Old Aug 12, 2007 | 07:33 PM
vibrating_cake
thanks, my first time with ohc engines
Old Aug 13, 2007 | 05:42 AM
Get yourself a proper tappet adjuster spanner it is so much easier!!
Ace engine one of the best ever IMO along with x/flow.
A 40DFI can work wonders on these when tuned, I always used them instead of 38dgas.
Old Aug 13, 2007 | 07:47 AM
vibrating_cake
does the 40DFI fit on the std inlet manifold, and does it fit well without much grinding for the larger size?
looks good, a lot more OEM
Old Aug 14, 2007 | 05:48 AM
I seem to remember it fits straight in place of a 32/36, but will not work with a std engine, was the performance upgrade for essex v6.
Finding one is another matter though now.
Mark RS
Mar 5, 2021 06:08 PM
tankybaby66
Feb 6, 2016 02:24 PM
locum8
Oct 1, 2015 01:50 PM
deathrider666
Sep 28, 2015 06:12 PM
