erst Oil Feed help
Hi All
I have s2 turbo lump which i brought second hand and have only tried it tonight. I've took the oil feed off the turbo, Now If i turn the engine over should oil come flying out of the oil feed pipe to the turbo? i haven't if so what would be the problem?
many thanks
many thanks
Being completely honest with you mate the few seconds it takes for oil to reach the turbo isn't going to kill it........its a wet floating bearing after all its hardly precision machined bearing units.
As long as you are sure there is nothing wrong with the engine/oil pump crank it over for a good 30 secs or so and then start it up, it will be fine.
Mc5506
Oct 5, 2015 09:57 PM
