He's right, if its got rear discs it should be the 130, you can also check the throttle body. If you take off the black air intake pipe and look at the throttle body, the butterfly inside should be nearly as large as the size of the throttle body aperture. The 105 throttle bodies are tappered and have a smaller butterfly. I have come across xr3i look alikes with the rear discs. Good luck
