amp cutting out, any ideas
Old Aug 12, 2006 | 03:27 PM
fast_ford_uk's Avatar
fast_ford_uk
Default amp cutting out, any ideas
right. i have a vibe active sub with inbuilt amp total 1200w, witch has its own power earth and remote, ive aslo got a splx 400w amp running some vibe 600w speakers through a 1 farad power cap. this has its own live and earth but i have split the remote. my problem is when the hole lot is turned up, when a large bass note plays my amp cuts out (splx)and the red light comes on. the power cap is reading around 13 - 14 volts, my first thought is that i might need a bigger alternator, but surely the power cap would have sorted it if it was taking too many amps. anyone have any ideas
thanks in advance
dan
Old Aug 12, 2006 | 04:40 PM
Alvyn's Avatar
Alvyn
you sure it's not getting too hot thus cutting out?
Old Aug 12, 2006 | 10:04 PM
HORNETS7's Avatar
HORNETS7
i think uve got the speaker wires to the sub round the wrong way on the amp!
ie uve got em bridged wrong?
Old Aug 13, 2006 | 08:03 AM
fast_ford_uk
yeh ive checked all the conections and they are fine, and it cuts out straight away when turned up lowd so it doesnt get chance to get hot, it will cut back in when the music bass changes if you no wat i mean, any more ideas please
Old Aug 14, 2006 | 08:56 AM
biglee's Avatar
biglee
Audio specialist
sounds like a load problem, ie the amp is seeing a low impedance and going into protect mode,
make sure your amp is not seeing under 3 ohms.
also you should be running at least 50% headroom with amps, so lets say you have 2x600w vibe black air drivers, there is a potential of 1200w. you should be running an amp that delivers at least 2000w to run correctly.
dont think if you run smaller amps into big speakers they wont blow your speakers, it is actually more likely to happen due to early square waves into your drivers, causeing coil destruction..
be carefull mate,, as you know vibe drivers arnt cheap lol
good luck, let me know if you need any help
Old Aug 14, 2006 | 10:27 AM
fast_ford_uk
alrite il check the ohms later and try a bigger amp as i have a few, and yeh it is going into protect mode. cherz for the help guys
Tank Mike
Ford Focus ST Parts for Sale
May 18, 2016 09:38 PM
cossirob
Sep 16, 2015 07:39 PM
rogerxr3i
Sep 13, 2015 06:56 PM
stevierob
Sep 7, 2015 07:09 PM
hopper350
Sep 4, 2015 12:53 AM
