Grey injectors and pintel caps??????????
Old Jul 23, 2006 | 08:18 PM
costina's Avatar
costina
Live long and prosper!!
Default Grey injectors and pintel caps??????????
Last time i fitted a set of greys i was advised to drill out the pintel cap to 7mm i can see the idea behind it but whats your opinions?
cheers
Old Aug 1, 2006 | 10:46 PM
costina's Avatar
costina
Anyone??????
Old Aug 2, 2006 | 12:06 AM
jon@work's Avatar
jon@work
Some people run without fitting the caps - I suppose in the belief that they will give a better spray pattern and the fuel will atomize better. If this is the case, then the larger the hole in the end of the cap, the better. Don't know if there is anything in this though - you'd be better off talking to a tuner you trust and following his/her advice.
Old Aug 2, 2006 | 07:48 AM
sailorbob's Avatar
sailorbob
Even though I've seen it done many times I've always been dubious about it, why would an injector manufacturer slap a cap on the end of an injector that would affect the spray pattern, it doesn't make sense. I'd like to see side by side comparisons on an ANSU cleaner to find out for sure but don't fancy butchering a cap needlessly.
Old Aug 2, 2006 | 08:15 AM
Alvyn's Avatar
Alvyn
run mine WITHOUT the caps and have no problems at all!
thought the cap was only there for protection of the needle jet incase it was dropped
regarding why you'd change what manufactors designed the 403's spray pattern with the cap on doesn't suit the Cossie engine was what I was told!
Old Aug 2, 2006 | 09:29 AM
costina's Avatar
costina
greys are fitted to jags as standard i think and do not run caps. this is why you need a fitting kit. so your changing the design of the spray pattern of injector by fitting a cap surely
any more ideas?
Old Aug 2, 2006 | 10:20 AM
sailorbob's Avatar
sailorbob
I thought the fitting kit for the greys was an adapter for the inlet manifold or fuel rail It gets more confusing!
Old Aug 2, 2006 | 11:50 AM
cossiegreg1's Avatar
cossiegreg1
i know a few lads and tuners who just remove end caps.
Old Aug 2, 2006 | 02:16 PM
Alvyn's Avatar
Alvyn
[quote="costina"]greys are fitted to jags as standard i think and do not run caps. this is why you need a fitting kit. so your changing the design of the spray pattern of injector by fitting a cap surely
you've got the wrong end of the info m8 as stated above the fitting kit is so it WILL fit onto the Cossie manifold,the caps I'm talking about are at the bottom of the injector!
Old Aug 2, 2006 | 06:59 PM
Billabong's Avatar
Billabong
What Alvyn said - the 403 injector wasn't OEM for a Cossie (US Ford V8 amongst others) hence the cap can cause problems on a YB engine. Best advice is speak to your preferred tuner.
Old Aug 2, 2006 | 07:06 PM
costina's Avatar
costina
I will take myself outside and have a word
going to leave caps on drilled to 5.5 mm.as they seat better in manifold.
cheers
Old Aug 2, 2006 | 07:48 PM
Stu @ M Developments's Avatar
PassionFords Creator
cheers
That will be fine.
The ONLY reason to use a cap is to stop the O ring falling off the bottom. LOL
This type of injector runs best with no cap at all. Leaving the cap on CAN and WILL cause an engine meltdown unless it is modified suitably. I personally chop the entire end of it with a stanley knife, far easier than pissing about trying to drill holes in the tricky little buggers. lol
Old Aug 2, 2006 | 08:19 PM
costina's Avatar
costina
Stu,cheers for that mate managed to find a way to drill em without killing them
Knew there was a good reason.Lol
be speaking to u soon mate, u know why
cheers
Paul
Old Aug 3, 2006 | 10:32 PM
cossie604's Avatar
cossie604
Another top tip off passionford I know what im doing to my injectors tomorrow lunch break at work now
Old Aug 3, 2006 | 10:43 PM
costina's Avatar
costina
I drilled mine using a large washer over top of pintel cap so i could hold in position.
using a stepped drill 4 to 22 mm drilled caps out to approx 5.5 mm could go more up to 7mm
by using a step drill it dosent catch like a normal drill
if u need a pic i can post some up tomorrow
Did not fancy the thought of only havin three fingers
Old Aug 4, 2006 | 09:40 AM
lawnsy's Avatar
lawnsy
I run my grays with no end caps at all and had no probs...
Old Aug 27, 2007 | 11:07 AM
Mark_w's Avatar
Mark_w
I have just fitted my greys and followed stu's advice...put cap on workbench and cut 2mm off the top with a stanley knife.when the cap was on,i then trimmed it down neatly.
mark
Nov 1, 2015 06:53 PM
Fil
Sep 30, 2015 12:08 PM
Alloy wheels and ICE for sale
Sep 28, 2015 06:19 PM
20/20 vision
Sep 28, 2015 03:03 PM
