oil coolers and roof linings
Two questions fellas.as above,is it difficult to get the roof lining out of a series 2 rst and put it back neatly enough to make it look untouched?Secondly if you fit an oil cooler wit a sandwhich plate between the block and oil filter,where is best to put the cooler and how much additional oil does it take?thanks in anticipation of a few replies :top: :top: :top: (hope I get some)
think i used about an extra litre of oil. i filled up to the max mark and turned it over for abit with the igintion coil off to fully fill the addition lines. oilcooler was already filled with oil. then started it for real and let it run for abit. re checked it and topped as nessecary.
as for the roof lining ive been told its a bitch. but id speak to some oif the peeps with cars in the restoration room. |
Cheers wutangrs.It gives me an idea.ta mate. :top: :top: :top:
© 2024 MH Sub I, LLC dba Internet Brands
