what does a standard chip look like
Old Jul 25, 2004 | 01:38 PM
the original's Avatar
the original
Default what does a standard chip look like
i guess they're getting rare now , but i'd like to know what the sticker on a STANDARD i.e. 204bhpish cossie eprom looks like. is it printed/ handwritten/ no label?
pics would be nice...
please??
Old Jul 25, 2004 | 09:47 PM
richm's Avatar
richm
sorry, don't know for certain about 2wd.. but for 4x4:
The label is handwritten with reference "L3e.31"
The outer label on the ECU also carries the same reference, so maybe 2wd is similar, with the external label reference matching the eprom label??
Old Jul 26, 2004 | 03:44 PM
Dave Henshall's Avatar
Dave Henshall
my L8 4x4 doesnt have that - that looks like a stg3 chip with pectel board IMO
Old Jul 26, 2004 | 04:01 PM
richm's Avatar
richm
Dave, that's a bog standard L8 ECU, baby board is fitted as standard to L8, the Pectel version is visibly similar, but obviously different electrically.
This particular ECU still had the Marelli seals intact before we took the lid off
Old Jul 26, 2004 | 05:00 PM
Andymancos's Avatar
Andymancos
Mine says 45/620 6y or 67 cant make it out
Old Jul 26, 2004 | 05:58 PM
Stu @ M Developments's Avatar
PassionFords Creator
It should look exactly like that Dave.
Old Jul 27, 2004 | 07:11 AM
the original
cheers.
2wd anybody?
Old Jul 27, 2004 | 08:15 AM
Dave Henshall
orrrr, unless mine wasnt a L8 and had been swapped at some time befor ei had it - but the seals were intact on min ebefore i had the ab stg 1 chip fitted. bizzare
Old Jul 27, 2004 | 08:05 PM
Maybe its a P8.
Does it have some large red capacitors inside it, near to the ECU connector in one corner? If so its P8.
Old Jul 28, 2004 | 07:27 AM
Dave Henshall
dont know, i sold it a couple of years back,, my escos is p8, but its phase 0 chip that was in it was not on a daughter board though.
Old Jul 28, 2004 | 07:42 AM
Certainly wasnt an L8 then thats for sure.
A L8 will work without the board but its virtually a crappy Level 6....
Old Jul 28, 2004 | 08:48 PM
2001ode's Avatar
2001ode
Hi,
Somebody knows where can I found a recap about all properties of
L1 / L6 / L8 / P8 ???
Thanks by advance.
Old Jul 30, 2004 | 01:41 PM
richm's Avatar
richm
https://passionford.com/forum/viewto...575&highlight=
Old Jul 30, 2004 | 08:20 PM
2001ode's Avatar
2001ode
Thanks, richm.
Very interesting post.
Regards.
Old Oct 7, 2004 | 10:54 PM
blaazer2's Avatar
blaazer2
it could say anything realy ,as it is not a special part, only the data in the chip is special, but when i program a chip for a cossie i normally use ......27g4a-15 chips ,the only real way of checking is to put your chip in a eprom pragrammer and veiw the data on it
Old Oct 9, 2004 | 08:26 PM
blaazer2's Avatar
blaazer2
the original, is that the bloke i bought the manifolds off at bruntingthorpe ,if it is get a picture of your cortina on this forum its cool
IainRS1700T
Sep 25, 2015 06:44 AM
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
timsrs
22
Sep 24, 2015 08:14 PM
L1AM_RS
Sep 23, 2015 03:27 PM
RSmark84
Sep 13, 2015 01:29 PM
