Technical essay Archives A collection of topics you really shouldnt have missed first time round if your interested in the technical aspect of how these Fords work..!! Also many Workshop manuals available in downloadable format. Access is available to Gold Members only.
Lack of power on hills fiesta zetec 1.25
Old 25-09-2013, 01:07 PM
Phil Munt
Phil Munt's Avatar
Unhappy Lack of power on hills fiesta zetec 1.25
Hi ,
My fiesta lacks power on hills as if the ignition timing is not advancing I realise that this is ecu controlled but is ther a sensor somewhere malfuctioning?
Old 28-09-2013, 09:44 AM
Mk4 Rick
Mk4 Rick's Avatar
Originally Posted by Phil Munt
Hi ,
Can you be more specific lol.A 1.2 is rubbish up hills any way.Mine was the same
Old 28-09-2013, 03:23 PM
Phil Munt
Phil Munt's Avatar
Well that sounds like you have answered my question rubbish up hills but on the flat fairly rapid. cheers.
Old 28-09-2013, 03:31 PM
Mk4 Rick
Mk4 Rick's Avatar
They are nippy on flat roads.
Old 05-12-2013, 10:38 AM
AstoN_B
An eye for detail...
AstoN_B's Avatar
This is comedy.
My advise is get an older 1.3 pushrod powered fiesta they're actually a decent little engine, not loads of power but good to drive.
Old 05-12-2013, 12:15 PM
martysmartie
martysmartie's Avatar
I think what is being confused here is lack of low down torque, the 1600 which is just a larger version of your engine is the same.
As said as a older engines were generous with this, but it seems modern multivalve engines need working hard to produce the goods.
Maybe change down a gear lol.
Martin
Old 15-01-2014, 07:20 PM
George_77
George_77's Avatar
Have you changed the timing belt recently? If yes there is a possibility that is not adjusted correctly...there is also a possibility that the cam sensor malfunctioning. If the cams timing is not correct then the cam sensor malfunctions also...So check the timing then the sensor, clean your throttle bodie and clean the injectors, then i believe you will be fine.
JK12
33
26-04-2021 12:09 PM
JoeyBoyden
20
22-08-2015 03:23 PM
Botts
13-08-2015 04:16 PM
tommylommykins
Ford Fiesta
08-08-2015 08:01 PM
creator
02-08-2015 12:24 PM
Quick Reply: Lack of power on hills fiesta zetec 1.25
