Technical essay Archives A collection of topics you really shouldnt have missed first time round if your interested in the technical aspect of how these Fords work..!! Also many Workshop manuals available in downloadable format. Access is available to Gold Members only.
cosworth oil pressure / oil cooler problem?
Old 12-11-2013, 07:10 PM
petemos
petemos's Avatar
Default cosworth oil pressure / oil cooler problem?
I have recently put a 9 row oil cooler onto my escort cosworth. I put the sandwich plate on the end of the arm between the filter. Now sometimes when starting the car the oil pressure takes a wee while to build up and the engine is knocking. Once the pressure is up its fine. I've noticed that it must be the oil cooler draining back into the sump as the oil level is rising above the normal mark and it must be the extra oil from the cooler and pipework......any ideas?don't want to feck my engine!
original
30-01-2022 08:20 PM
Chas
21-09-2015 08:57 PM
Stu @ M Developments
41
21-08-2015 06:47 AM
14-08-2015 07:29 AM
mattman1234
24
01-08-2015 11:46 AM
Quick Reply: cosworth oil pressure / oil cooler problem?
