Technical essay Archives A collection of topics you really shouldnt have missed first time round if your interested in the technical aspect of how these Fords work..!! Also many Workshop manuals available in downloadable format. Access is available to Gold Members only.
digital to cable speedo converter
Old 24-05-2013, 07:59 AM
Paul81
Paul81's Avatar
Default digital to cable speedo converter
Hi im doing the st170 box conversion an I see this on the net
http://www.highperformancepontiac.com/t ... converter/
has anyone seen anything like this in the UK
Thanks Paul
Old 31-05-2013, 09:53 PM
shalon
shalon's Avatar
looks brilliant i would buy one for a mtx if available so i could use original clocks
Old 04-06-2013, 11:55 AM
Paul81
Paul81's Avatar
I got an email back from Abbot about the Cable X an they seem to think it will be fine they supply the right push fit to fit the stranded fiesta speedo an they wont $514.95 delivered witch is about Ł341 then there will be import tax to go on top
Old 04-06-2013, 06:12 PM
shalon
shalon's Avatar
sounds expensive but when you compare to buying and installing digital dash etc plus it keeps the car looking original inside etc
Old 04-06-2013, 06:48 PM
Paul81
Paul81's Avatar
yeah should work out about Ł400 ish witch is expensive really but will get to keep original clocks seems like the only way to go for me have bin looking at digital dash lay out but really don't like the look of any of em an really wona keep the car looking OE going to be hard with a 2.1 Zetec turbo with 6 speed box under the bonnet but even that im trying to get that looking like its has always bin there is hard work lol
Old 06-06-2013, 10:47 PM
stevieturbo
C**t
stevieturbo's Avatar
www.speedycables.co.uk can convert the clocks, but they arent cheap by any means.
I have one of those Abbot-X boxes if you're interested ? I used it on my car for a few years until I ditched the old mechanical clocks.
Mine has a short cable, about 16" long to old Ford clocks fitment. Again, the cable I had made by speedycables.
Abbot X werent able to supply me with one as they werent familiar with the car.
On my car it worked fine up to about 100mph, after that it stopped working. Not sure why, might have been the cable route was too tight and too difficult for the motor to turn, as in order to fit it behind my dash, I had to do a full 180deg turn
Also read this thread. Not sure if they ever got a working unit yet.
http://ls1tech.com/forums/conversion...-solution.html
Only other option might be to see if the box can be converted for a mechanical output. Not always easy though.
Old 07-06-2013, 07:52 AM
Paul81
Paul81's Avatar
Yeah something that goes on the back of the Speedo would be good so what would you be looking for your one
muz
30-09-2015 08:29 AM
cossie brad
29-09-2015 02:38 PM
mondeomark
28-09-2015 06:28 AM
Bransby
14-09-2015 08:54 PM
Neil Clark
08-09-2015 07:06 PM
Quick Reply: digital to cable speedo converter
