2wd or 4wd cossie head
Is there a difference between the 2wd head and the 4wd head? If so what is it
Oil feed for one , come out the side by the turbo on a 4x4.
Damper also , doesn't have a mounting bracket thing on the side . Not alot else but I'm sure others will no mire |
combustion chambers are smaller on 4x4. SO compression will be raised if a 4x4 head is used with 2wd pistons.
Late spec 2wd and 4x4 head used a redesigned waterway on the exhaust side. Valves, Guides, Cam(s) bearings and spacers different on 4x4. |
also more oil ways up to the inlet cam
© 2024 MH Sub I, LLC dba Internet Brands
