Mk2 Fiesta ST 170
Old 20-03-2022, 08:19 PM
  #161
boost monster
boost monster's Avatar
So with his Golf R sold the 2JZ BMW still a while away the Fiesta will be getting some use (when the salt is off the roads). Priority was some way the charge a phone and a cup holder!!
The flexible fuel lines had started to perish so this was completely re done with hard pipe and an fittings.
A much tidier solution
A switch was added to the clutch pedal so flat foot shifting could be enabled.
Old 04-04-2022, 12:25 PM
  #162
boost monster
Pedals and cam cover painted and installed.
USB charger fitted, it’s a disgrace Ford never fitted this when the car was new!🤣🤣🤣
I like his attention to detail adding the little bracket so the clutch switch is being pushed in its designed direction.
USB c
Old 23-04-2022, 09:24 AM
  #163
boost monster
Spot the difference. Four years between these pictures
Mark V8 (17-09-2022)
Old 23-04-2022, 11:12 AM
  #164
XR2
XR2's Avatar
No wiper motor???
Old 23-04-2022, 03:35 PM
  #165
boost monster
Originally Posted by XR2
No wiper motor???
That was a lockdown project to mount it on the inside to clean up the bay. Works as normal.
Old 25-04-2022, 02:21 PM
  #166
boost monster
Attended Crail 1/4 mile drag strip yesterday and was timed at 13.9@105. Fastest in its class (up to 2 litre fwd)
Old 03-05-2022, 12:48 PM
  #167
boost monster
Well just when I thought it wouldn’t be developed anymore he has started collecting parts for a ST170 gearbox this has very similar ratios to the IB5 he made from several boxes but obviously has another gear to make it slightly more bearable at motorway speeds. Ear protection is required atm with the engine screaming at cruising speeds. Oh and a rear beam to modify to give so negative camber to control the oversteer action on track.
A picture of progress of his 1 series.
Realistically this is still a few years away.
Old 12-08-2022, 03:38 PM
  #168
boost monster
After another alternator failure (3 in 3 years) he done some calculations and it’s spinning at 22k at maximum engine speed even at 5k engine speeds the alternator is above the15k maximum and with the crazy gearing, cruising on the motorway is 5k!!!
A new voltage regulator and larger pulley should have it going again.
Old 15-09-2022, 12:01 PM
  #169
boost monster
Finally a better breather system.
This part is on the block. It’s a nicely machined piece.
Stealth catch can.
st220kyle (15-09-2022)
Old 17-09-2022, 08:03 AM
  #170
Mark V8
Mark V8's Avatar
Breather setup look great, what have you done where the fumes come out, did you run a pipe away from the engine bay to stop any smells?
ITB's don't make it easy for sorting engine breathing!
Old 04-10-2022, 06:14 PM
  #171
boost monster
There is a filter on the catch can (no shown in the picture) that he hope will stop any fumes but there may be further revisions as this is rev.2 the first attempt didn’t go well 😬
Mark V8 (04-10-2022)
Old 21-12-2022, 01:45 PM
  #172
studabear
studabear's Avatar
A great build, bet its a load of fun on the road.
Old 28-12-2022, 01:49 PM
  #173
boost monster
Yes it’s a absolute riot.
He said to me the other day that there can’t be many fiesta’s like his with a lower top speed… it goes from 0- max in around 17 seconds the 60-100 time is up there with some decently fast cars.
Old 11-04-2023, 05:58 PM
  #174
boost monster
This was delivered a few weeks ago. 🤔
Old 15-04-2023, 07:21 AM
  #175
PaulinhoT
PaulinhoT's Avatar
Lovely this build, well done.
boost monster (15-04-2023)
Old 23-04-2023, 12:54 PM
  #176
boost monster
No progress on the Fiesta NOS installation but plenty on his other project.
If any Ford fans are interested in a German car with a Japanese engine here are some pictures. It does have a Cosworth radiator.
How it is atm. Wiring just started, all fuel, oil and water lines are done with just the boost control solenoid to finish.
4” downpipe. I think the whole exhaust will be 4” to be bigger than his brother’s turbocharged Integra😁
Old 12-05-2023, 06:51 PM
  #177
boost monster
NOS installation has begun.
Also a delivery from BMW for his 1 series
Wings,quarters,side skirts and bumpers….. 1M parts
Old 27-08-2023, 06:29 PM
  #178
boost monster
No more updates for a while☹️
He has never finished the NOS install due to spending all the time on his 2JZ 1 series and realistically you can only do one at a time.
The MOT ran out last week and it will go into hibernation until the BMW is completed.
He has plenty of things to do before it comes out again, obviously finish the NOS and install the ST170 gearbox with a plated diff. that he has waiting.
Old 22-12-2023, 01:35 PM
  #179
boost monster
As explained no progress on the nos or the ST170 gearbox fitting but new parts that I have never seen before have been bought.
One of the first things son No.1 did when he purchased the car in 2011 was the fit the Engelmann mirror (copies) and now we have Ford branded Engelmann copies?
Anyone seen them before.
The mirror’s currency fitted
Sports mirrors.
The look the same as Engelmanns.
….but with Ford branding.
Old 22-12-2023, 02:29 PM
  #180
XR2
XR2's Avatar
These look like wing mounted mirrors?
Old 23-12-2023, 04:35 PM
  #181
boost monster
I think you may be correct. We don’t have them yet so we’ll see🥴
Old 24-12-2023, 01:16 PM
  #182
XR2
XR2's Avatar
Probably RS Accesoires for Taunus/Cortina, Granada or Capri.
st/dom/leic
Fiesta
22-04-2013 12:54 PM
scott1987
68
02-02-2010 03:59 PM
Nash
13
22-12-2008 02:38 AM
cabrio boy
08-12-2008 07:18 PM
BillyCabrio
40
11-01-2005 04:14 PM
Quick Reply: Mk2 Fiesta ST 170
