St 170 restoration.
St 170 restoration.
Recently picked up my 03 plate st 170 in panther black its got 64k and had only 2 owners from new and has the climate pack.car is very straight and has no rust at all.going to tidy up the underside and engine bay also planning some mods will add pics as i do the work if i can work out how to post pics lol.
Sounds like an interesting project, good luck.
Couple of pics of the car decided to jack it up and give the underside a jetwash so it will be pretty clean before i start doing some work on the underside.
Received 1,042 Likes
It will defo be a rare car if there is no rust on it.
I used to have a ST170 with bothe climate ans custom packs. It was a bit tatty. The sills and front wings had bits of rust on them.
All looks great so far a nice choice.
Im glad there was no rot anywhere i was dreading pulling those rear arch linners out as i know they can rust quite bad behind there my next job is to be removing the rear sub frame.
A very nice looking car look after it
Managed a few hours work this evening having already removed callipers and hubs thought i would tackle the rear subframe gave all the bolts a good soaking with wd40 there are 10 bolts bolting the subframe to the underside of the car these came off with no prob as for everything else was pretty seized so out with the impact wrench which loosend everthing up so dropped the subframe of in one its bigger and heavier than it looks next will be to dismantle and shot blast and powder coat.
That must be the only focus rear subframe in history to come apart without a slitting disc! You lucky git!
lol alot of the bolts were seized couldnt budge them even with power bar but used impact wrench which did loosen them up loosend everything while the subframe was still bolted to car for stability but the 2 lower wishbones which hold springs up were loose but couldnt remove out of the bush so i did have to cut these of with disc cutter.
