Rosso red Rs turbo build and progress.
Old 26-01-2022, 03:14 PM
  #2361
Rsmat
300+
PassionFord Gold Member (Male)
Rsmat's Avatar
Originally Posted by Adam-M
Hope you get it sorted mate. As a side note, i know you’re right into your detailing, what would you recommend for black plastic trim to shine it up and remove polish residue?
​​​​​​​Hi mate I use a pad from CYR called a dubba scrubber for residue and the stuff I use on the trim I can't remember ill take a pic for you when home tonight and post up .
Adam-M (28-01-2022)
Old 27-01-2022, 09:18 PM
  #2362
Rsmat
300+
Rsmat's Avatar
So a good friend of mine suggested that the Mk ARB would be far superior to the TT ARB and that i should try a standard Arm and if it fitted then I could you a compbrake adjustable arm , so last night I did exactly that and it fitted like a dream. Rosso red Rs turbo build and progress.-wekrgt4.jpg ​​​​​​​ Rosso red Rs turbo build and progress.-ygxloap.jpg ​​​​​​​ Rosso red Rs turbo build and progress.-a9o03qv.jpg ​​​​​​​ Rosso red Rs turbo build and progress.-svve0kg.jpg ​​​​​​​Rosso red Rs turbo build and progress.-ojj5pu7.jpg ​​​​​​​ Rosso red Rs turbo build and progress.-mbjlvdz.jpg Rosso red Rs turbo build and progress.-4llgmox.jpg Rosso red Rs turbo build and progress.-50ox4so.jpg So this makes the Mk tcas redundant so they are going back for a refund , Sierra ones don't fit escorts its simple wrong angle and too big ball joint . ​​​​​​​Had a massage off G.O.N.E today they are chasing my sump.and breather up with the powder coaters so hopefully I may have them back next week
Old 27-01-2022, 09:20 PM
  #2363
Rsmat
300+
Rsmat's Avatar
Also to add I need to make a spacer to space the top rose joint from compression strutt to blade . 10mm .
Old 27-01-2022, 09:36 PM
  #2364
ajamesc
cossie fan (unluckerly)
ajamesc's Avatar
Nice your finding solutions be a serious spec car when you have dialled it all in
Rsmat (27-01-2022)
Old 27-01-2022, 09:47 PM
  #2365
Rsmat
300+
Rsmat's Avatar
​​​​​​​thanks mate , I'm trying my best to make the changes and keep positive , then I can get it powder coated and dialled in
Old 28-01-2022, 04:09 PM
  #2366
Adam-M
Adam-M's Avatar
https://www.ebay.co.uk/itm/ford-sier...-127635-2958-0
Don’t know if these are any good to you Matt? Looks like you can still run an arb with them
Old 29-01-2022, 05:22 PM
  #2367
Rsmat
300+
Rsmat's Avatar
https://www.ebay.co.uk/itm/ford-sierra-wishbone-kit-cosworth-capri-escort-100e-105e-cortina-classic-car-/133025252640?mkcid=16&mkevt=1&_trksid=p2349624.m46 890.l6249&mkrid=710-127635-2958-0 Don’t know if these are any good to you Matt? Looks like you can still run an arb with them
​​​​​​​Hi mate , no they wouldn't fit also . ​​​​​​​Going to use compbrake ones.
Old 29-01-2022, 07:31 PM
  #2368
Rsmat
300+
Rsmat's Avatar
Been with Raj at AutoFlock today and he says my ceramic coated parts will be ready by Friday/ Saturday, I cant wait tbh , the sunp should also be on its way back and the build up.
Old 30-01-2022, 07:45 PM
  #2369
RUBY123
RUBY123's Avatar
Thumbs up
make sure the rose joint is screwed far enough in the adjuster and far enough in the tie bar.its hard to explain but the rose joint thread has to be far enough in to the tie bar otherwise your relying on a thin wall adjuster you obviously wont be able to tell till its all set up for length but from them pc it looks over adjusted
Rsmat (30-01-2022)
Old 30-01-2022, 09:29 PM
  #2370
Rsmat
300+
Rsmat's Avatar
Totally got you mate , and great info , it's just mounted loose at the moment . Waiting for my combrake tcas to come.
Old 31-01-2022, 09:27 PM
  #2371
Rsmat
300+
Rsmat's Avatar
Ordered my comp brake Tcas and super pro bushes for them to match my super pro kit . Will get pics as stuff arrives . If anyone want to buy the Turbo technics ARB then it will be for sale
Old 01-02-2022, 07:35 PM
  #2372
ajamesc
ajamesc's Avatar
Couldn’t fault my compbrake tca’s and compression struts it just all worked as it should
Old 03-02-2022, 06:50 AM
  #2373
Rsmat
300+
Rsmat's Avatar
​​​​​​​cheers mate , that's reassuring .
Old 03-02-2022, 02:43 PM
  #2374
Rsmat
300+
Rsmat's Avatar
The TT ARB is now sold to Boost Monster .
boost monster (03-02-2022)
Old 05-02-2022, 11:57 AM
  #2375
scoooby slayer
scoooby slayer's Avatar
Have you done any timing yet mate 0-60 mph and 100-200 kmh ?
Old 05-02-2022, 12:14 PM
  #2376
Rsmat
300+
Rsmat's Avatar
No mate , I might get some done this year once the boost is back up and the new tweaks are all dialled in and running.
Old 06-02-2022, 01:55 AM
  #2377
Rsmat
300+
Rsmat's Avatar
So this week,some parts have arrived and info on the bits I need are in hand sump might be back next week as it's powder coaters holding it up. ​​​​​​​The A.L Developments copper T3 gasket arrived and my super pro bushes for the Tcas . ​​​​​​​Compbrake bushes arrived also . ​​​​​​​Raj at Auto flock started coating my bits . ​​​​​​​ ​​​​​​​ Rosso red Rs turbo build and progress.-qdjdwhe.jpg ​​​​​​​ Rosso red Rs turbo build and progress.-arh3zyg.jpg ​​​​​​​Rosso red Rs turbo build and progress.-wwdueqk.jpg ​​​​​​​ Rosso red Rs turbo build and progress.-jlibcvy.jpg ​​​​​​​ Rosso red Rs turbo build and progress.-hg1vjlz.jpg ​​​​​​​ ​​​​​​​ g]https://i.imgur.com/gorf9sz.jpg[/img] ​​​​​​​ Rosso red Rs turbo build and progress.-usyjrmr.jpg ​​​​​​​ g]https://i.imgur.com/WIVgTEd.jpg[/img]
Old 06-02-2022, 09:25 AM
  #2378
bluntys1rsturbo
Boost addict
bluntys1rsturbo's Avatar
fantastic updates mate, look forward to seeing you and the car again in a couple weeks
Rsmat (06-02-2022)
Old 06-02-2022, 05:00 PM
  #2379
Rsmat
300+
Rsmat's Avatar
Cheers mate im hoping all parts will be back by then tbh ,
Old 13-02-2022, 10:40 PM
  #2380
Rsmat
300+
Rsmat's Avatar
A little update of whats been going on , finally got the ARB and combrake Tcas fitted , so now needs Geometry when back running , Picked up my Turbo rear housing , manifold and down pipe from autoflock and fitted up today . ​​​​​​​Rosso red Rs turbo build and progress.-o1om94j.jpg​​​​​​​Rosso red Rs turbo build and progress.-tu9lz6s.jpg ​​​​​​​​​​​​​​Rosso red Rs turbo build and progress.-mxvm42x.jpg ​​​​​​​ Rosso red Rs turbo build and progress.-ggnlnyd.jpg ​​​​​​​ Rosso red Rs turbo build and progress.-2lvkhnj.jpg ​​​​​​​ Rosso red Rs turbo build and progress.-mep2a2i.jpg ​​​​​​​ Rosso red Rs turbo build and progress.-t4yasvi.jpg Rosso red Rs turbo build and progress.-zbn5r4r.jpg​​​​​​​ Rosso red Rs turbo build and progress.-qytpuzw.jpg
Old 20-02-2022, 09:07 PM
  #2381
Rsmat
300+
Rsmat's Avatar
Nice push this weekend and got the car back together , just a few bits left to do .. need to order some fittings and some An12 hose for the breather return to sump. Whilst underneath the car I found the gear selector rod knuckle joint with too much play it in , so I'll take off and send to Dave Fox for a bush conversion. ​​​​​​​Also our DJI osmo action is itching to get used . ​​​​​​​Rosso red Rs turbo build and progress.-bgbco8l.jpg ​​​​​​​ ​​​​​​​ Rosso red Rs turbo build and progress.-9cw0y5v.jpg ​​​​​​​Rosso red Rs turbo build and progress.-7axujyo.jpg ​​​​​​​ Rosso red Rs turbo build and progress.-qr7ihc7.jpg
Old 20-02-2022, 09:50 PM
  #2382
Rsmat
300+
Rsmat's Avatar
Old 21-02-2022, 05:06 PM
  #2383
james kiely
james kiely's Avatar
great update matt.car gets better and better mate
Rsmat (21-02-2022)
Old 21-02-2022, 08:41 PM
  #2384
Rsmat
300+
Rsmat's Avatar
Thanks mate , I keep finding things to adjust / make better
Old 21-02-2022, 09:46 PM
  #2385
Rsmat
300+
Rsmat's Avatar
Another little touch done tonight , made some end caps for the ARB up at Autoflock. Rosso red Rs turbo build and progress.-kakpnyx.jpg ​​​​​​​Rosso red Rs turbo build and progress.-werslbo.jpg​​​​​​​​​​​​​​Rosso red Rs turbo build and progress.-zmrn1kt.jpg ​​​​​​​Rosso red Rs turbo build and progress.-1syqmj7.jpg ​​​​​​​Rosso red Rs turbo build and progress.-nyadlcl.jpg ​​​​​​​Rosso red Rs turbo build and progress.-h8dzpfq.jpg ​​​​​​​
Old 23-02-2022, 03:57 PM
  #2386
bluntys1rsturbo
Boost addict
brilliant updates mate, was good to see the car again last weekend
Old 24-02-2022, 08:11 AM
  #2387
Received 1,044 Likes on 998 Posts
Too work again Mat.
Old 26-02-2022, 04:03 PM
  #2388
Rsmat
300+
Rsmat's Avatar
Cheers lads , some more bits been made and added this weekend. Rosso red Rs turbo build and progress.-emuqqdd.jpg ​​​​​​​Rosso red Rs turbo build and progress.-8bmgmbq.jpg ​​​​​​​ Rosso red Rs turbo build and progress.-pvb5krv.jpg ​​​​​​​
Old 26-02-2022, 04:23 PM
  #2389
Rsmat
300+
Rsmat's Avatar
Had the game the gear linkage off due to too much play , so off it came and was sent to dave Fox, who's made replaceable nylon bushes for it as opposed to going KA linkage .. very impressed . Rosso red Rs turbo build and progress.-erkq7bo.jpg ​​​​​​​ ​​​​​​​Rosso red Rs turbo build and progress.-9ngor8f.jpg ​​​​​​​Rosso red Rs turbo build and progress.-j7ezags.jpg ​​​​​​​Rosso red Rs turbo build and progress.-qqmdvuw.jpg ​​​​​​​​​​​​​​Rosso red Rs turbo build and progress.-jgydmb4.jpg ​​​​​​​Rosso red Rs turbo build and progress.-ygmievt.jpg ​​​​​​​also some pics from My Gated sump from G.O.N.E ​​​​​​​​​​​​​​Rosso red Rs turbo build and progress.-xddhszb.jpg ​​​​​​​Rosso red Rs turbo build and progress.-nqr8yem.jpg
Old 02-03-2022, 05:59 PM
  #2390
Rsmat
300+
Rsmat's Avatar
Tonight my sump arrived Rosso red Rs turbo build and progress.-rarzycq.jpg ​​​​​​​Rosso red Rs turbo build and progress.-i7kqurh.jpg ​​​​​​​ Rosso red Rs turbo build and progress.-an17agy.jpg ​​​​​​​Rosso red Rs turbo build and progress.-hz9a0ja.jpg
Old 02-03-2022, 08:53 PM
  #2391
james kiely
if you sloweed down going around the corners you wouldn't need a gated sump matt
top job as usual mate
Rsmat (02-03-2022)
Old 02-03-2022, 09:29 PM
  #2392
Rsmat
300+
Rsmat's Avatar
if you sloweed down going around the corners you wouldn't need a gated sump matt  top job as usual mate
​​​​​​​Mate these roads here scream to be driven.
​​​​​​​And thanks mate
james kiely (03-03-2022)
Old 07-03-2022, 06:29 AM
  #2393
Rsmat
300+
Rsmat's Avatar
Managed to do a little more this weekend , Shame I ordered the wrong fittings for the sump otherwise it would have been done and out . So sump on and gear linkage built back up. Rosso red Rs turbo build and progress.-whfo7j1.jpg ​​​​​​​Rosso red Rs turbo build and progress.-2bkfyfo.jpg ​​​​​​​ ttps://i.imgur.com/e3MTSag.jpg[/img]
Old 07-03-2022, 06:31 PM
  #2394
fatty
fatty's Avatar
Originally Posted by Rsmat
Managed to do a little more this weekend , Shame I ordered the wrong fittings for the sump otherwise it would have been done and out . So sump on and gear linkage built back up. ​​​​​​​ ttps://i.imgur.com/e3MTSag.jpg
looks great. Nice one .
I welded baffles into my sump and added a fitting for an oil temp sender ,...painted it black ...fitted it...and have been chasing what must be a pin hole leak for ages!
regretting the black now
Old 09-03-2022, 08:30 PM
  #2395
Rsmat
300+
Rsmat's Avatar
Slight delay on the build up , had to have a fitting moved on the breather as it ran to close to the down pipe and also the gasket on the sump wasn't right and was found to be a deformed one . So it's a few days delay .
Old 10-03-2022, 08:04 AM
  #2396
bluntys1rsturbo
Boost addict
all easily sorted matey although still a pain
Old 12-03-2022, 05:27 PM
  #2397
Rsmat
300+
Rsmat's Avatar
Back on all 4s , need to investigate and hopefully just nip the sump up a little more , slight weep flywheel end. So only a few little jobs to sort ​​​​​​​Raise the front.​​​​​​​put exhaust back on the rear hamger ​​​​​​​get out and see how it drives / collect data .​​​​​​​​​​​​​​arb off and powder coated ​​​​​​​Geometry book and take / set up. ​​​​​​​Here's an Update Vlog ​​​​​​​
ajamesc (12-03-2022)
Old 12-03-2022, 08:54 PM
  #2398
Mark V8
Mark V8's Avatar
I would keep a close eye on the anti roll bar drop link extensions mate, there's going the be a lot of leverage and bending forces going through them.
Rsmat (12-03-2022)
Old 12-03-2022, 09:00 PM
  #2399
Rsmat
300+
Rsmat's Avatar
Totally will be doing mate, . Most of the rally cars run the same and same thickness and material so I should be fine , but will deffo be keeping an eye on it all , before I confirm it's a green light .
Old 14-03-2022, 12:20 PM
  #2400
Rsmat
300+
Rsmat's Avatar
Went out for the first time and things wasn't the best , Geometry needed ASAP and fix oil weep . Vlog ​​​​​​​
Quick Reply: Rosso red Rs turbo build and progress.
