Rosso red Rs turbo build and progress.
Old 24-10-2021, 06:42 PM
  #2281
bluntys1rsturbo
Boost addict
bluntys1rsturbo's Avatar
lovely little collection mate, cant beat some new garage goodies
Rsmat (24-10-2021)
Old 24-10-2021, 10:01 PM
  #2282
Rsmat
300+
PassionFord Gold Member (Male)
Rsmat's Avatar
New coil pack on to try before I relocate it up into the bay .
Also modded the oil pump for some more pressure across the scale.
Old 24-10-2021, 10:03 PM
  #2283
Rsmat
300+
Rsmat's Avatar
Cheers mate , your totally right on that.
Old 25-10-2021, 08:32 AM
  #2284
RSGARETHW
always working
RSGARETHW's Avatar
looking good
Rsmat (25-10-2021)
Old 25-10-2021, 09:49 AM
  #2285
Rsmat
300+
Rsmat's Avatar
Originally Posted by RSGARETHW
looking good
Cheers sweet cheeks .😘
Old 25-10-2021, 10:13 AM
  #2286
Rsmat
300+
Rsmat's Avatar
New lifters En route to mine , after speaking to Newman direct they are kindly sending me some more .
Happy days .
Old 25-10-2021, 11:29 PM
  #2287
Rsmat
300+
Rsmat's Avatar
Tonight I've fitted a new Mac Valve and then took data from the old oil pump spring and new one and are as follows .
Old spring at 90° oil temp at 3.7k = 40psi (218kpa)
New spring at 90° oil temp at 3.7k = 75psi (519kpa)
So will now get our and see how it goes and try cal3 to see if I've solved the mis fire..
If not new leads and plugs next and probably a new coil driver.
bluntys1rsturbo (26-10-2021)
Old 26-10-2021, 03:34 PM
  #2288
bluntys1rsturbo
Boost addict
absolute result there mate and nice to have the date proving its made a massive difference
Old 26-10-2021, 10:12 PM
  #2289
Rsmat
300+
Rsmat's Avatar
Great result.. reset the ECU data log and went out to grab fuel and collect some data / have fun .
So I get out nice and steady and then once at temp I give it a couple of pull at WOT in cal2 and try a pull at cal3 and feels quicker ..so I pull in into the petrol station and full it and head back out to try and watch the digital boost gauge on the zeitronix monitor in cal3 but I bumped into a mapped new shape focus St which I managed to dispense very easy , then after a short cruise I get upto what I call my testing circuit through the mountains and give it some boost in cal3 I recall glancing down and seeing more boost. So after a few pulls and some ALS on the way home I get home and cool the car down and down load the data and send to Mark Knight who takes a good look at it and confirms we are now hitting more boost in cal3 without mis fire ..so to say I'm happy is an understatement ..
New oil spring hasn't added much at idle but up at high boost added 0.5bar of oil pressure..its running sweet so I'm well happy
Out boosting .
Old 26-10-2021, 10:16 PM
  #2290
james kiely
james kiely's Avatar
nice one matt
Rsmat (27-10-2021)
Old 27-10-2021, 06:53 AM
  #2291
Rsmat
300+
Rsmat's Avatar
nice one matt
Cheers mate . The not very old coil , must have started to break down on the run to MSD .
Old 27-10-2021, 09:31 AM
  #2292
ajamesc
cossie fan (unluckerly)
ajamesc's Avatar
Top work as normal bet your chuffed now
Old 27-10-2021, 11:26 AM
  #2293
Rsmat
300+
Rsmat's Avatar
Thanks mate, was nice to see that mis fire gone and the boost needle fly past 18psi
ajamesc (27-10-2021)
Old 27-10-2021, 09:11 PM
  #2294
Canada1
Canada1's Avatar
Fantastic.
Need some in car videos accelerating in 3rd gear. - 60 to 120kph must be insane.
I would imagine 18 psi is useless in lower gears
Rsmat (28-10-2021)
Old 28-10-2021, 06:25 PM
  #2295
Rsmat
300+
Rsmat's Avatar
Originally Posted by Canada1
Fantastic.
Cheers, will get some good videos up soon .. the car doesn't spin it has boost by gear and TC ..18psi pull here on this vid from other night.
Old 28-10-2021, 06:29 PM
  #2296
Rsmat
300+
Rsmat's Avatar
Many thanks to Newman cams for the new Solid lifters.
Old 30-10-2021, 09:29 PM
  #2297
Rsmat
300+
Rsmat's Avatar
Since the car is where I want to be and the weather is turning foul I've decided to get a few jobs done that I've wanted done for a while .. first one is my MK motorsport ARB which as been and too for nearly 3 years ..it all fits as it should apart from the TCa end , so next weekend I'll be going up to explain this one last time as it seems to get missed by messenger or what's app everytime . So tonight I've started fitting the bits that do fit right .
And here's the bit that's wrong , only thing to get sorted and it's a fitting ARB.
Old 30-10-2021, 09:34 PM
  #2298
markk
markk's Avatar
Christ, not again. Get over there and don't leave till he sorts it.
Rsmat (30-10-2021)
Old 30-10-2021, 09:44 PM
  #2299
Rsmat
300+
Rsmat's Avatar
Your right, it's getting sorted . Be over there next week.
Old 30-10-2021, 09:49 PM
  #2300
ajamesc
ajamesc's Avatar
That man is an absolute knob I couldn’t deal with him I’d hit him round the head with it. He is no engineer he copy’s other peoples work and gets it’s wrong. The man’s a welder and a cnc operator that’s it. I sold his junk to someone who wanted it and fitted compbrake stuff. It fits it works. Best of luck getting your stuff sorted I hope you get what your after!!
Old 31-10-2021, 06:16 AM
  #2301
Adam-M
Adam-M's Avatar
I had the exact same bother with my tca’s, clown tried to tell me i was the only person with issue’s. They where much longer and taller than standard cossie items. Had to mod them myself and Martin at Reyland kindly made me custom bells and calliper brackets to mount the discs 5mm further away at no additional cost over a standard AP kit.
Mark Walker is absolutely hopeless
Old 31-10-2021, 08:57 AM
  #2302
Rsmat
300+
Rsmat's Avatar
I certainly won't be changing anything else to accommodate these TCas they can be sorted and made right , not a big job imo just the ends are way too big .
Old 31-10-2021, 09:43 AM
  #2303
Adam-M
Adam-M's Avatar
Yeah they look about 20-30mm longer than the standard ones (from arb hole to hub side). Hopefully just shortening the pins helps
Old 31-10-2021, 05:54 PM
  #2304
Rsmat
300+
Rsmat's Avatar
Little update from my channel
Old 01-11-2021, 12:48 AM
  #2305
james kiely
nice update matt
Old 01-11-2021, 05:56 AM
  #2306
bluntys1rsturbo
Boost addict
Great updates mate, YouTube vid is spot on.
Old 01-11-2021, 04:39 PM
  #2307
ajamesc
ajamesc's Avatar
Great vid Matt I can’t wait to be where you are fine tuning bits. I’ve the same roll bar set up. I’ll mod my compbrake tca’s to attach the rose joints that bolt to the blades
Old 01-11-2021, 10:50 PM
  #2308
Rsmat
300+
Rsmat's Avatar
nice update matt
Thanks James mate .
Thanks mate and thank you for the feed back.
Thanks mate , and yea its nice position to be in , I wish now I'd have kept my combrake TCA's as this would be in now , but easy little mod now and it will all fit .
Old 01-11-2021, 10:52 PM
  #2309
Rsmat
300+
Rsmat's Avatar
Old 04-11-2021, 07:38 PM
  #2310
Rsmat
300+
Rsmat's Avatar
Update .
Pins are off to MK motorsport tomorrow where the insert into the hub wants 3mm machining out ..and 6mm off the underside lower red line and the they need cutting at the top of the thread and 12mm of new thread cutting in and then they will clear my disks .
Old 04-11-2021, 07:41 PM
  #2311
Rsmat
300+
Rsmat's Avatar
Old 04-11-2021, 07:44 PM
  #2312
Rsmat
300+
Rsmat's Avatar
Some more parts arrived today , some for my collection stack of parts for future restoration . And the NOS strut bearings.
Old 05-11-2021, 02:36 PM
  #2313
Rsmat
300+
Rsmat's Avatar
YouTube update on the ARB / TCA's
Old 05-11-2021, 09:25 PM
  #2314
james kiely
ace bit of kit matt,
do you think it will take a bit of setting up ?
Rsmat (09-11-2021)
Old 06-11-2021, 12:43 PM
  #2315
Rsmat
300+
Rsmat's Avatar
Thanks mate .
I think so yea , it's been brought to my attention that it may not have enough pivot on the bearing, if this is the case then the lower joint is too big , I think im going to ring MK Monday and explain it needs to be right rather than fuck about.
Once one I'll have it all set up properly ( Geometry)
james kiely (06-11-2021)
Old 08-11-2021, 09:13 PM
  #2316
Rsmat
300+
Rsmat's Avatar
Last night given I've a trapped nerve in my neck I got stuck in and got the coil overs off to change the top bearings, I actually found the real issue ..there should be a second nut to lock down the billet top plate to lock the springs down , however it seems I missed them off and hence the coils spun and sounded bound .so easy fix and new bearings in anyway.
Also I'm very happy with how good condition they are to say they have done 12k mileage for 2 years in all weathers , can only thank the coating I coated then in .
Even the gearbox was coating.
Canada1 (10-11-2021)
Old 14-11-2021, 09:08 PM
  #2317
Rsmat
300+
Rsmat's Avatar
Little update.
So I've removed my Gated sump and sold it on , I've also made the call to MUZ @ G.O.N.E for a new Gated sump but with a fitting in to accept a return from my breather kit .. coil overs are now back on and need setting up ..also Mark at MK will have sorted my TCA's and should be back this week and should now fit , so feeling hopeful .
Old 18-11-2021, 10:46 PM
  #2318
Rsmat
300+
Rsmat's Avatar
Trigger wheels done by Dave at XYZ Fabrications .. had the little boy helping me also.. nice little winter mods and tidy up now , ready for some more boost in 2022.
Old 19-11-2021, 03:29 PM
  #2319
Caddyshack
Caddyshack's Avatar
Received 1,033 Likes on 945 Posts
Did you use Acf coating on the Shox? Or something else….I can’t believe how untarnished they look
Old 19-11-2021, 09:22 PM
  #2320
Rsmat
300+
Rsmat's Avatar
Hey up mate , no I've used KKD R-evolve on all my running gear it's mega stuff, heat proof ceramic coating. It's certainly done its job .
Quick Reply: Rosso red Rs turbo build and progress.
