Rosso red Rs turbo build and progress.
#681
Cam cover needs to be red matt that looks minted
Rsmat (19-04-2018)
#689
Them rockers sure look priddy Mr
Rsmat (20-04-2018)
#694
300+
Well yesterday was a write off as the youngest lad came of his push bike ..so today I have to make up for it spent a couple of hours cleaning the bulk head and restoring the wiper mechanism etc ..then fitted my new small dealer plate just the right size to get as much air to the IC as possible .
Old vs New .
Painted my boost pipe satin black to match the rest .
Then put it away .
Old vs New .
Then put it away .
Rsmat (24-04-2018)
#698
Made a propper nice job on that mate
Rsmat (24-04-2018)
#701
Mat have you thought about zircoating your manifold ? May help with how close your charge carrier is and possible heat transfer
Rsmat (28-12-2018)
#703
Sweet mate may give you a shout on that will need mine doing when I get to that stage
smiley (25-04-2018)
#706
300+
Mixed emotion day ..started getting fittings fitted ready for making all the hoses up etc ..then decided to tackle the door catch that had previously been messed up by someone in its past ..and slipped with the drill ..proper gutted ..but atleast it's only paint and it's all going for repair once it's running .
Also new dial decals arrived from Lockwood for my spare set of 88spec clicks ..and a mk6 peddle rubber to match the rs turbo original rubbers .
#709
300+
Aye mate ..luckily got a mate to sort the little bits out ..and yea I've tried eBay can only find 2 that are miles away.
#710
Boost addict
one thing i learned from summat similar years ago is to double tape the area and then stick a layer of duct tape over that, might seem a bit ott but it defo does the trick.
#718
Boost addict
think that might be your best option, if you notice anything show up around my way or in the staffs moorlands then id have no probs going fetch it and posting it to you foc, would be least i could do for all the help you have given to me this last few months
