Focus RS MK1 with WRC influence
#121
Thanks Jon, I think next time I'm up your way will be to pick the car up so might be after the event
However, if I can I will take you upon that - very kind of you.
3DOOR ARY (28-07-2017)
#122
If you need any information let me know
#124
Not much of an update as I've been too busy to get to see mark, but he has tackled a small problem I had. When I had the side exit exhaust fitted the guy cut through the sill without asking me first. I asked mark to sort it and sort it he did.
Cut out and metal replaced
Nicely tigged in
Boxed off inside
Nicely tigged in
Boxed off inside
jonfoc (28-07-2017)
#126
Just another small update. Shell is nearly finished and mark has been busy sorting the hydraulic handbrake. I supplied the Tilton cylinder and Mark did the rest
jonfoc (02-08-2017)
#128
Cheers Ben. I'm guessing yours will be having lots of carbon stuff??
#130
Not at first, purely because of budget But eventually I would like a carbon fibre roof skin and tailgate to help with weight distribution. Not bothered about bonnet as I need as much weight there as possible so I bet it will end up handling it's best with a full tank of fuel.
The JWRC kit is fibreglass/kevlar so it's pretty light already.
Have you got any carbon plans?
#132
#134
All in good time mate. Once the shell is back the build will start
#135
Time for a little update. Progress has slowed mainly due to my work comments and that's there's little to do.
Mark has cracked on with my sill stands and touring at style column.
Great welding as usual
#136
And column pictures
Column outer
Welding porn
Mounting lugs
Low friction bearing
Column outer
Welding porn
Mounting lugs
#137
They look great, will you powder coat them?(the sill stands)
#138
I really like your work it's pure art
#139
PaulinhoT (14-09-2017)
#141
The column is finished. Beyond my imagination this thing! I'm so glad I trusted Mark with my project, his vision and ability is 2nd to none.
Thank you Mark
Thank you Mark
STeve (24-08-2017)
#142
As I'm going full coilover I'm. I'm not going to need spring arms on the rear. Mark has made me these things up. Spherical bearing at one end and a rose joint at the other. They will have more bracing added and lugs for the bladed arb.
The pedal box is on it's way too
#143
Awesome shell, love it. Cant beat a few holes to make stuff look cool
#144
Thanks Toby. It'll not be that much when you buy it.
#145
Oh and trust me my ability is lacking. Luckily I've a couple of ex pro drivers who have offered to coach me.
#152
There was something niggling me about the cage, something was missing. Then I realised what it was.
#155
If I'm ever in a car crash I'd sure like to be in this one!
Not that I ever want this car to be crashed, that would be soul destroying.
The TIG welding is still stunning
#156
It does look a very cool cage. If I ever rebuild my 205 I will probably do this but think I would always want to wear a crash helmet and full harnesses in it.
jonfoc (16-09-2017)
#157
Yeah I know what you mean Toby. It will have 6 point harnesses in it and my head is nicely between a sparco pro circuit winged seat. I won't be taking it on the road that often.
#158
Another quality update from Mark. This time in the shape of a bladed rear arb. The usual quality workmanship.
