Focus RS MK1 with WRC influence
#81
Mark has already left his marque!
#82
Doesn't that make it a write off? Lol
#83
I am beginning to think my car needs to be re registered as an MK special and not a 205 pug. He is texting me pics of my fuel rail with other bits i want in the pics....
jonfoc (28-06-2017)
#85
Thanks Dave. I'll be wanting a switch panel making soon if you're up for it?
#87
Not much of an update but every little helps. Popped up to see Mark today to see the car in the flesh. It's better than I thought. Marks work is beyond reproach. I ordered a couple more bits of work and Mark showed me the base plate for the hydraulic hand brake. It'll be a bit of a centre piece in the car.
#89
Brilliant work, liking this a lot
jonfoc (01-07-2017)
#90
jonfoc (02-07-2017)
#92
That handbrake looks soooo cool, as long as you don't bash your elbow on it.
#94
Black and gold is the future!
#96
Great work , just a quick one how are you going to seal the rear adjustable top mounts ? Your car will be full of water when your driving it in the rain , best bet would be to get mark to machine a nice billet cover that bolts over the parts lol .
Iam sure mark could machine a real nice cover that could be anodised
Keep up the good work
Cheers paul
Cheers paul
#97
To be fair Paul I was wondering this myself. It certainly won't be a billet cover though. Anyway what's all this driving in the rain nonsense?????
I know mark reads the thread so I'll expect a message in the morning
#98
Cheers paul
rathbone (10-07-2017)
#99
I think I'll try and address the issue from underneath. Some kind of plastic bowl that will bond to the top spring cup and cover the hole. Like a small plastic inner wing thing
#100
Yeah, I was thinking seal from below, even a thin piece of rubber and just pierce a small hole where the strut comes up through, pond liner would be tough enough...let me know if you need some to try, my mate runs a rubber factory, he makes the masks that fighter pilots use and I have quite a bit here where I sealed up my intercooler and he dropped off loads of grades to try.
#101
#104
To be perfectly honest mate doubt I'll gain anything in it's current form (fwd). I've built in quite a bit of adjustment in the rear beam already. It's more of a future proof thing so that if I wish to go rwd or 4wd I can give it plenty of scope for adjustment. It's also about the WRC theme of the build. I wanted to go full coilover so I needed a turret modification as you can only just squeeze a skinny damper in running a 1.9" id spring as a standard car. With this turret I could run a very robust damper and a 2.5" id spring
#106
To be honest mate I don't think it will give me any benefit whilst I am still front wheel drive. I have a very adjustable rear beam set up in position already. I asked Mark to put them in so that I could future proof the car as I do wish to turn into rear wheel drive or possibly four wheel drive in the future then I believe I will gain some benefit from it. It also keeps with the theme of the world Rally car style build. I'm also running a full coilover set up if I kept the car with standard rear suspension pick ups I would only be able to run a 1.9 inch diameter spring. With the set up I can run a more robust damper with a 2.5 inch internal diameter spring.
#108
Because if the damper leans so will the upright.
#112
Sadly it doesn't work like that on a fwd focus. That's why I have adjustable rear arms
jonfoc (11-07-2017)
#114
Thanks mate. The plan is to go rwd or 4wd in the future. The problem I have is I like to do things to the best of my budget, if that means saving for a couple more years so be it. The cost of going rwd is huge. I'd want the WRC cradle the uprights the x-member etc etc. That's a good few £k more. So the best fwd is where it's going for now while the bank recovers
#119
That's fair enough. None of it is cheap, and I can see you're getting the foundations for the options later which I think is wise. Will be a fantastic car and absolute weapon when finished.
I've spied some ideas in the adjustable stuff for the front subframe which should work for the rear of mine.
Top quality stuff
Top quality stuff
#120
Next time you're up my way if you want to see it in the flesh let me know. Kettle is always on.
moondustka (11-07-2017)
