Mash's ST170
STeve (24-08-2017)
#82
I'm going to try and come, but May the 6th is a long time off in the world of my ST
STeve (01-09-2017)
#83
Bought this off ebay "spares or repairs" 60 quid
Quick bit of re-connecting the speaker cables with shrink connectors, connected up to my loom. Made some slight alterations to Kenwood head wiring, changed settings to send sound to sub, and tested. Awesome bit of AC/DC blasting out
Already fitted the Audiophile front speakers I got from ebay for a tenner, so pretty happy
#84
Looks good, I've often wonder how good these sound let me know
#88
Managed to get two of these fairly cheap, ready for my next project when i have the space to start it.
Tried this one in the ST to see what it's like and it's really comfy, almost tempted to get some for it I particularly like the longer base they have as it gives more support under the knees, this photo shows the extra length a little better.....
PaulinhoT (01-09-2017)
#93
That looks alright, doesn't it
#94
An old rocker at heart then? hope to be down your way in a couple of weeks time, if I hear ac/dc I will know its you.
I wish I had more space, there is never enough!!
ref. a question you asked about the bottom ball joint ( I think ) yes they are all the same but if you are thinking of putting RS hubs on a st170 I believe you will have problems with the drive shafts
cheers
cheers
Mashurst (02-09-2017)
#95
So is that why you fitted the RS drive shafts to your project then mate? that's what made me think it was worth a shot, seeing what you've done with that.
Give me a shout when you're down this way maybe we could meet up and compare cars, get that Paulinho out too
Mind you, I'll be away myself quite a bit in the next few weeks
PaulinhoT (02-09-2017)
#96
Sorry just read your question again, the strut on the RS is bigger in diameter than all the other focus's. The genuine ones are reasonably priced used but you will not be able to use those nice new Bilstein's from your st sorry
#97
Yes you need to fit the RS drive shafts and they do not fit in the st170's gear box as far as I am aware.
will probably be in the wife's car as its cheaper on fuel but will get in touch
#99
The Focus with the RS bits started out as a 2.0
Hubs and struts came from st-breaker who have a pair of hubs listed now for Ł250 the front brake callipers were from eBay and there are at least 2 pairs available as I write this for Ł260 or Ł300 mine came from an Alfa Romeo which made them a bit cheaper you will need new discs and pads which are widely available. Struts and drive shafts do come up for sale if st-breaker does not have them just remember to get the bearing support, be prepared that your wheels may not clear the callipers obviously RS wheels do and seem to come up regularly on eBay not cheap though
#100
Thanks Mate. Drive shafts isn't a real problem for me as my project will be RWD (I must be mad ). but I do plan to utilise the existing front suspension. I may have to use the hub end of the shafts to secure the hubs to the knuckles, as i think they are only pressed in? My RWD Transit pretty much uses FWD hubs with dummy shafts in, so that's what I'm hoping to do.
Just bought the hubs from ST-breakers actually, and have some Fiat coupe calipers which I think are the same as the Alfa ones. My plan is to buys some new RS struts or coilovers to sort it.
To start with, I'll be doing the work with the standard ST suspension to ee how it goes, but am getting the bits together now, as I don't see the prices going down at all If it doesn't work out as planned, I can always sell them on later.....
You probably think i'm a nutter
#101
Not at all!! considering my collection of cars, which if your ever passing I would be happy to show you round, your plan is quite sane. Have some time off work soon so hope to restart an Escort project which has a rwd zetec if so will start a thread.
I also made a conscious decision to buy RS parts so that they would be easier to sell on.
Mashurst (05-09-2017)
#103
Just went and bought the airbag module that you advised and it's not the same as in mine...
I need to look for another one...but I think I've already found it...
Mine is the one on top...
#104
Hmmm, strange
Anyway, question for you guy, do standard Mk1 Focus drive shafts fit into MK1 RS hubs? I need some so I can use the ends to secure my RS hubs on my RWD project, and R shafts are few and far between......
#105
A longer answer, found my spare RS hub and a scrap drive shaft today and tried to put them together. The diameter of the shaft is smaller than the RS one which means that the splines do not locate in the hub, not sure if this would be a problem for your intended use.
Mashurst (17-01-2018)
#108
My Transit works in the same way, it's a RWD, but all Ford have done is used spline ends to hold it all together at the front, and the rest of the front end, hubs and struts and stuff, are the same as the FWD version.
I've managed to source one RS shaft now for the offside, just need a
NS one now and I'm sorted
PaulinhoT (17-01-2018)
#110
Good to hear although my head unit doesn't play cd's
#111
I had a couple of issues with humming and buzzing, but it was down to my dodgy wiring into the head unit. I fixed that an it's been fne ever since. When you crank it up it really does add plenty of bass
PaulinhoT (03-03-2018)
#113
#115
EDIT: just found the picture of the module...look for the reference 2M5T14B056BD . When you get it, and compare to your module, you'll see where you have to cut the tabs.
Ben-B
121
06-01-2015 08:04 PM
