Mk2 2door Cortina 1600 TT
#42
after a week of work shell has made progress
o/s sill all fitted
<a href="http://s1002.photobucket.com/user/timbhp/media/Mobile%20Uploads/IMG_20160831_184052.jpg.html" target="_blank"><img src="http://i1002.photobucket.com/albums/af148/timbhp/Mobile%20Uploads/IMG_20160831_184052.jpg" border="0" alt=" photo IMG_20160831_184052.jpg"/></a>
n/s striped
<a href="http://s1002.photobucket.com/user/timbhp/media/Mobile%20Uploads/IMG_20160831_184019.jpg.html" target="_blank"><img src="http://i1002.photobucket.com/albums/af148/timbhp/Mobile%20Uploads/IMG_20160831_184019.jpg" border="0" alt=" photo IMG_20160831_184019.jpg"/></a>
all cleaned up and n/s sill and A post in place
<a href="http://s1002.photobucket.com/user/timbhp/media/Mobile%20Uploads/IMG_20160903_142911.jpg.html" target="_blank"><img src="http://i1002.photobucket.com/albums/af148/timbhp/Mobile%20Uploads/IMG_20160903_142911.jpg" border="0" alt=" photo IMG_20160903_142911.jpg"/></a>
then removed some panels not req'd
<a href="http://s1002.photobucket.com/user/timbhp/media/Mobile%20Uploads/IMG_20160903_163608.jpg.html" target="_blank"><img src="http://i1002.photobucket.com/albums/af148/timbhp/Mobile%20Uploads/IMG_20160903_163608.jpg" border="0" alt=" photo IMG_20160903_163608.jpg"/></a>
now got to bend roll cage and get it welded in to shell
o/s sill all fitted
n/s striped
timbhp (07-09-2016)
timbhp (07-09-2016)
#45
new bit of kit to make the cage
<a href="http://s1002.photobucket.com/user/timbhp/media/Mobile%20Uploads/IMG_20160907_181350.jpg.html" target="_blank"><img src="http://i1002.photobucket.com/albums/af148/timbhp/Mobile%20Uploads/IMG_20160907_181350.jpg" border="0" alt=" photo IMG_20160907_181350.jpg"/></a>
this is the front hoop and dash bar with centre hoop in the back ground
<a href="http://s1002.photobucket.com/user/timbhp/media/Mobile%20Uploads/IMG_20160907_181410.jpg.html" target="_blank"><img src="http://i1002.photobucket.com/albums/af148/timbhp/Mobile%20Uploads/IMG_20160907_181410.jpg" border="0" alt=" photo IMG_20160907_181410.jpg"/></a>
they have turned out really well
Mark V8 (07-09-2016)
#47
well done a bit more on the car
bending front hoop to centre hoop bar above door
front and centre hoops in place with dash panel cut and fitted around cage
bars all tacked in place ready to be removed and welded up
back out off the shell and roof cross being made and notched
welded cage with a bit of colour on it once on chassis there will be rear legs with cross added and a few more sections,
also replaced rear valance and made a mounting bar for bumper as the original bumper mountings were part of the chassis legs
also this will be connected to the rear of the new chassis as to give support to the rear of the shell
valance removed
new valance with support bar will weld supports in place when on chassis
hope to have cage in shell over the next couple of weekends
valance removed
#48
Where do you get your energy? Can never understand how some spend 8-12 hours a day working on other peoples cars and then home to spend god knows how-many hours working on your own.
No matter how many times I read this thread I'm stunned. Cortina II's are now up to 50 years old and yet new and amazing creations like this still spring up each year.
#49
and at lunch time instead of sitting down i can get an hour in on the chassis at work so its a win win situation
i have always liked the lotus cortina's so i thought id make a replica with a bit of difference
#51
Hellraiser (02-11-2016)
#53
wow, get me the pop corn looks epic.
#54
Right had a good day on car
got cage all back in position level and central
Then started on gusset's to secure the cage to body first one in place ready to fit
Hope to have all gusset's in and fitted by next weekend then can bring rolling chassis home to make mtg plates and fixings to mount the body
timbhp (30-10-2016)
#57
Pooh, this is going to be a big thread. Love it
#58
Ok a few pic,s of progress
Body down on floor
<a href="http://s1002.photobucket.com/user/timbhp/media/Mobile%20Uploads/IMG_20161119_190934_1.jpg.html" target="_blank"><img src="http://i1002.photobucket.com/albums/af148/timbhp/Mobile%20Uploads/IMG_20161119_190934_1.jpg" border="0" alt=" photo IMG_20161119_190934_1.jpg"/></a>
chassis under body
<a href="http://s1002.photobucket.com/user/timbhp/media/Mobile%20Uploads/IMG_20161127_123137.jpg.html" target="_blank"><img src="http://i1002.photobucket.com/albums/af148/timbhp/Mobile%20Uploads/IMG_20161127_123137.jpg" border="0" alt=" photo IMG_20161127_123137.jpg"/></a>
<a href="http://s1002.photobucket.com/user/timbhp/media/Mobile%20Uploads/IMG_20161127_123056.jpg.html" target="_blank"><img src="http://i1002.photobucket.com/albums/af148/timbhp/Mobile%20Uploads/IMG_20161127_123056.jpg" border="0" alt=" photo IMG_20161127_123056.jpg"/></a>
front view
<a href="http://s1002.photobucket.com/user/timbhp/media/Mobile%20Uploads/IMG_20161127_122900.jpg.html" target="_blank"><img src="http://i1002.photobucket.com/albums/af148/timbhp/Mobile%20Uploads/IMG_20161127_122900.jpg" border="0" alt=" photo IMG_20161127_122900.jpg"/></a>
lots of room up front for charge coolers and charge cooler rad and main rad plus oil coolers
<a href="http://s1002.photobucket.com/user/timbhp/media/Mobile%20Uploads/IMG_20161127_123016.jpg.html" target="_blank"><img src="http://i1002.photobucket.com/albums/af148/timbhp/Mobile%20Uploads/IMG_20161127_123016.jpg" border="0" alt=" photo IMG_20161127_123016.jpg"/></a>
it is now taking shape at last but still a lot of work to do
Body down on floor
chassis under body
front view
#64
tried some tyres under the back these are 285/18s
may see if can get 335/18 under as i will need to try and put the power down
http://i1002.photobucket.com/albums/af148/timbhp/Mobile%20Uploads/IMG_20161212_150611.jpg
side shot these are not the wheels i will use
http://i1002.photobucket.com/albums/af148/timbhp/Mobile%20Uploads/IMG_20161212_150600.jpg
#68
<a href="http://s1002.photobucket.com/user/timbhp/media/Mobile%20Uploads/IMG_20161212_150611.jpg.html" target="_blank"><img src="http://i1002.photobucket.com/albums/af148/timbhp/Mobile%20Uploads/IMG_20161212_150611.jpg" border="0" alt=" photo IMG_20161212_150611.jpg"/></a>
<a href="http://s1002.photobucket.com/user/timbhp/media/Mobile%20Uploads/IMG_20161212_150600.jpg.html" target="_blank"><img src="http://i1002.photobucket.com/albums/af148/timbhp/Mobile%20Uploads/IMG_20161212_150600.jpg" border="0" alt=" photo IMG_20161212_150600.jpg"/></a>
#73
the clutch and flywheel assembly has arrived they claim it will take 1950lbft of torque
twin plate
concentric release bearing
a lot of bits have arrived from the usa so can start getting the engine ready to start up
will be a bit more regular with posts now
twin plate
timbhp (21-04-2017)
timbhp (21-04-2017)
#80
Your project is really looking mighty, very impressive skill set you have. This car will become one of those iconic builds that go down in history as legendary
