My new (older) car
The only way is dagenham
My new (older) car
Hey all, well i felt its time for a change. I have just bought off my mum her 1988 xr3i. It's in a pretty decent Nick but does need TLC
How ever it's first problem poped up to day, it took the car out for a drive and it run lovley, didn't overheat or no weird noises, how ever I pulled into the drive and left the car running. I must of left it for 10/15minutes and i go back out to it and steam was pooring out the bonnet and the temp was up in the red. Now i know old cars over heat but surly it wouldn't get that worm that quick at a stand still???
Looks like a tidy shell. What's the plans for it then?
Sounds like the cooling fan isn't working? I wouldn't have thought it would boil over that quick either, maybe it could do with a bit of a refresh on the cooling system. New rad, flush the block through, new water pump etc.
Cheers dude, i'll look into the fan to day. So have you had a few of them then?
Well Sam I'm a bit if a technophobe as you know!!!
Plus I guess because itll be a long time before anything gets done to it!
But you never know one day!!
1x white rs turbo rep full kit on it and interior
1x white cab custom bumper, rs kit, rs interior
1x black one slammed on the floor
1x red rs turbo rep inside and out
1x maroon convertible converted to rs running gear
and a few others over time.
Your overheating problems sound the same as what I had on my D plater many years ago.
Try a new header tank cap(it may have failed) sort out a new thermostat, if possible go for a lower temp one. Flush the coolant system taking hoses of from the heater matrix on the bulkhead and put a hose to it. Same for the radiator too. For the sake of it i'd be looking at a new fan switch and fitting a new modern fan or 2. maybe a fan over-ride switch fitted on the dash somewhere.
Yeah I remember you mentioning that, didn't you have a black one too?
