Radiant Red Fiesta RS Turbo progress/build
#42
Thanks. Escort paint job is abit poor. Looks like its had too many coats of paint, something to sort out at somepoint, plus when I had the N/S sill replaced the bloke tacked the front wing 5mm to close to the door and thus touches the door at the bottom.
The Fiesta is pretty tidy, I wouldnt mind having the roof painted as it look like cats/birds have scratched it.
#43
Should have asked, what are you doing about the spare wheel? i binned my tray off as the bolt was rotten to the holder and it was twisted, and I hate under boot spare wheels. Ive yet to bolt in a spare wheel post.
#44
Boost addict
its something iv not thought about yet lol, i know the spare is in the boot atm and there is a tray under there so its something we will investigate if we can refit the wheel there then we will if not then will remove the tray and go from there.
#45
On a tangent
Top choice on the pipe front....whats it off ERST?
REF the spare wheel, I binned mine off but kept all the tray, and the hanging brackets as I took em off chassis for a smoother look...
I actually went out and cleaned mine out yesterday, Mrs fraggle has had a meltdown and is realising just what my little beast means too us...glad I left your thread open in me phone hahaha
#46
Boost addict
haha thats great to hear fella hopefully its back out boosting soon
Fraggle... (05-03-2016)
#47
Boost addict
nothing too major to update on other than my rocker cover/exhaust manifold and thottle bodie gaskets and new sump plug and washer arrived from matt lewis.
got 4 new uniroyal rainsport 3 tyres on monday so they will be fitted in due course
also new front brakes have arrived.
oh and i also forgot to mention this turned up today
now it will look and sound like an rs turbo should do
#49
Boost addict
got a nice update for you all
my hybrid t2 is all built up and ready to come back to me courtesy of wilky (bernies blowers) and its a proper bernie special.
consists of 360 bearing, escort cosworth t28 comp wheel and nissan t28 turbine all machined into oe housings so should make for a nice turbo and keep the oe look
bluntys1rsturbo (02-04-2016)
#51
Boost addict
i can only go off what my bros old castle performance stage 2 used to drive like and i remember it being super responsive with adequate poke, my thinking is to get the response of a t2 with a good solid 180-200bhp and around 200-220 lbft should make for a really quick car point to point
JK12 (02-04-2016)
#54
What is the plan for the car? Resto? Performance? Or both? Like the exhaust are you going to fit a set of 16" alloys on or stay with the standard wheels?
#55
Boost addict
sticking with the oe wheels, its got to have the period 4" exhaust and im still loving the fact iv got a proper original scorpion to put on.
if i was going for power then i would not really bother with the cvh and go full 16v turbo but im more than happy to get around 200bhp on this car and still have the oe response and have it looking mostly original
#58
Boost addict
well after a long lay off of being able to work on the car me and my good mate karl finally got chance to do some more work on it, everything was going really well until we fount that my banjo bolt for the turbo oil feed hadnt been sent back so scuppered everything as that needs fitting in order to complete the other jobs.
but we got the following done
firstly had to take a pic of the car and engine before we started
removed rocker cover and fitted new rocker cover gasket as old one was split and slight leak to it.
all nice and clean under there
also fitted new amal valve
got the turbo and manifold built back up
new exhaust manifold gasket and 5 new manifold studs, all being fitted with new nuts and washers.
the cleaned throttle bodie and throttle cable have been refitted (didnt get a pic of this)
fitted new front discs and pads
old
new
check it out iv got brembos haha
and a pic of how the car sat before we left it, obviously was covered back up
i am hoping to receive banjo bolt from wilky asap so we can get the turbo fitted and then all related parts
old
new
#60
Boost addict
well this is an update thats happened much quicker than we thought, banjo bolt was fount and we were able to get the car put back together and up and running she now has new 10/50 oil and filter in there and new coolant as well.
didnt get many pics as it was typically british weather but did get this
and this taken by karls wife when doing the oil change
oh and a small video of the 1st start up (shes alive)
http://vid428.photobucket.com/albums...psk1zg69ns.mp4
looking forward to fitting the scorpion rear box to give it that proper rst sound.
#61
Boost addict
well we have another really good set of updates so here goes
last night i managed to get a few unplanned hours on the car and this is what was done
fitted new fuel filter
fitted replacement brake master clylinder and put new brake fluid in
managed to have a play and set the co at idle and all i can say without a gauge/machine it a mile better smells alot less rich and sounds much more like a cvh turbo.
tomorrows jobs are the following
fit drivers side headlight bulb
sort the horn as not working and looks like its been bodged to make work in the past
check handbrake as it might need a tighten up
bleed brake system and top up accordingly
if get time refit rear view mirror and take a look at why reverse light isnt working.
oh yeah and the big news is that the car is booked in for its m.o.t at 2pm on Saturday 7th May and regardless of result the car will be coming back to my place for the 1st time since i have owned it
#64
Lovely car. Always loved these. The brake servo is in an odd place on these, almost as if it was designed as a left hooker, must have just been a space thing.
#69
Boost addict
as above the car didnt go for its mot on saturday due to me feeling a bit unwell but the good thing is the horn/headlights were sorted and last night i popped across and a new alternator belt was fitted along with refitting the spare wheel into the proper place.
we are now just awaiting 2 relays to arrive from good old ebay and were then all ready to roll with the newly rebooked mot this coming saturday at 10am
#70
Boost addict
my good mate karl3dr off here sent me these few pics of the car at the weekend, i think hes developed a crush on the little fiesta
yes i know the backbox is off centre (soon to be removed and replaced with scorpion) and also the paintwork is booked in to be fully paint corrected soon also
#73
Boost addict
well M.O.T day is finally here and the car is all ready to go been running it up over the last few nights to clear some of the oil out the exhaust system from the old turbo failure.
also had time to give the car a quick wash and really quick go over with ag srp defo made an improvement i think you will agree
#74
Boost addict
well heres the long awaited update from yesterday
the car failed the mot but really on nothing major
failed on the following
handbrake below efficiency
rear brakes imbalanced/uneven 62%
then 2 anti roll bar link dust covers and one ball joint dust cover deteriorated
steering rack gaiter split
it also requires 2 bits of welding on subframe and rear axle.
this didnt dishearten me at all as it was nice to finally drive the car and we certainly did a great job of setting the fuelling it flew through all the emissions tests.
the car drove lovely and the new turbo really does work well i only gave it a couple of tickles as i want make sure its set up properly before going mad.
i also had my 1st offer to buy the car within 5 mins of being out in it
got various pics throughout the day
with its big brother before heading to mot
little lennon getting his 1st ride in the RS
at the mot station
on the way back
finally back at home for the 1st time since iv owned it
my goddaughter has staked a claim for the car already
at the mot station
on the way back
#75
Nice job
Won't take you long to sort them bits
We should arrange a PF meet for our Northwest Members
There's more and more of us appearing slowly
I'm also waiting to here back off Oulton Park regarding Gold Cup this year
I organised a stand for a few of us last year, so maybe get a PF one together?
Great weekend
Great weekend
#76
did you find the cause to the fault regarding the reverse light?
I've been out in mine lately, I Put it on the road 1st may. I've done just shy of 80 miles, I've had to fit a replacement heater fan as the factory fit one needs attention, My ignition relay was getting hot. So I replaced that but now my boot popper doesn't work on that relay. Still works on the old one.
#77
Boost addict
nice to hear that you have been able to do a few miles i cant wait to do the same
the relays do seem a bit on off dont they and it looks like my fuse box has got hot at some point
Nice job
Great weekend
Great weekend
its going take a while the bits arrived yesterday but its going be a few weeks until we get any free time to sort it.
a pf meet would be cool and id defo be up for it
I really wanna do the gold cup this year still yet to do it keep me updated on the stand etc
#78
Boost addict
well after what seems an eternity i finally have an update
yesterday we finally fitted the following
x2 anti roll bar link
x1 track rod end
x2 steering rack gaitors
x1 handbrake cable
x2 rear brake cylinders
x2 set of new rear brake shoes
so apart from the welding its ready to go for mot hopefully have it in for welding either end of this month or start of next.
also had my mate ryan frm r&k detailing do a 3 stage correction on the car its come up much better but he was adamant it all needed wet sanding to get a top finish but that was outta the question due to costs etc.
here are a few pics not the best
oh alo karl took a quick video of me turning the car around
http://vid428.photobucket.com/albums...psyzu9clod.mp4
x1 track rod end
x1 handbrake cable
#79
Looks great as it is now. Only things letting it down is lack of badge on the rear and the post 2000 badge. Needs the light blue ones to finish it off.
My FRST went in for its MoT wednesday, It failed and I told them to do the work themselves... I doubt it'd be seeing it let alone getting it back any time soon.
#80
Come on lol. It looks mint Andy 👍
