Big build getting back on track
#82
Happily retired
Happily retired
I have taken advice on this from people that know .
#88
Mark
#90
Happily retired
Here what was recommended. Your verdict would be appreciated. I knew it was a test thing only fitting. I had visions of these things snapping as soon as we started up after your comment . These people also suggest only 6mm of probe into the port whats your view on that.
Stinger Pro Series Top Alcohol Probe Single 72 inches, Part# 4025R-72-R-0
This sensor is recommended for the following applications;
- Pro Stock
- Top Alcohol Dragster
- Top Alcohol Funny Car
- Top Alcohol Drag Boat
- Pulling Tractor (No Diesel)
- Drag Bikes
- .250" Dia.
- Wire Length is 72" inches w/ striped leads.
- Kapton Insulated Stainless Steel Overbraided Wire.
- Response time 300 milli-seconds All Day Long!
- Exposed Tip Junction Hyper Response can see a single misfire @ 8000 RPM.
- Type “K” Calibration Special Limits, Traceable to N.I.S.T. Inconel Outer sheath good to 2200 + F
- This Probe is compatible with...Race Gasoline, Alcohol, Methanol,E85 or Nitrous Oxide in naturally aspirated, Turbo charged, Blown/Supercharged Engines.
#91
Happily retired
Forgot to say maybe you can get them cheaper or suggest another make this is from Gas Technologies in the States. Of more interest is a suggestion for a EgT/CANbus amplifier. Looked at Haltech, 2d , KMS, TF Electronics & a few others not a clue whats suitable.
#92
They look fine Rod. When you fit them, you want the probe tip to be exactly half way into the exhaust port, so bang in the centre. Once fitted with the olive clamped on, you can then bend the rest of the thermocouple to get it away from heat sources. Put some heat proof tape on the wire coming out of the thermocouple too. You don't want it to fail just because it's melted the wire.
If it's a case of a few days test work, you should be fine with 3mm. But if you're happy with response of the 6mm, you can be pretty sure they won't ever break.
When they fail they tend to go open circuit. So will read 1200degC ish so lookout for that.
Best thing you can do is fit them to the manifold, then fit the manifold to the engine. Routing the leads away from heat
#94
Where are you planning to mount the voltage booster and battery?
If it were me I would have another booster just for the ignition coils and injectors. With a constant output of 13-18V you would not need to calibrate battery voltage correction tables for dwell or injector opening/dead times...
Do you have any info regarding the current you expect the fuel pump to draw at full load? I can't see any information about the current output from the voltage booster vs voltage etc.
Good luck!
Rob,
Good luck!
Rob,
#95
Good luck!
Rob,
Good luck!
Rob,
Mark
#96
I can see the inlet ports have been knife edged, is this head any different to what my head will be when we do it or are they similar spec 500bhp to 1000bhp?
#97
Caddyshack (25-09-2015)
#98
Happily retired
Have run this Accuvolt system since 2004 max of 16.25 volts. It supplies Fuel pump & CDI module that feeds the coils. We can run big plug gaps at very high boost without blow out. The FMS runs over 20v if required but can be switched off by the ECU when high volts are not required.
#100
Drawing 10A at 20V for example would normally mean a pretty significant voltage drop by the time you were at the pump, unless the booster in in your boot with the battery.
Looking forward to more pics of progress
#101
Happily retired
Thats cool, I was more wondering about where it was located in the car etc?
Always had 15+V at the pump. The unit is under the bonnet & been there for 11 years. Everything else has changed & this pic is 640bhp engine many years back.
#102
That'll be a waste gate issue more than likely, depending on where the actuator was taking it's pressure reference from. If it was coming off the compressor cover then that's just down to the extra oxygen from the gas
#103
Happily retired
JamesH- Ive found a 3mm o/d probe that's made of Inconel the other probes ive looked at don't mention material. From my design days its seems unlikely Inconel will fail through Vibration am I correct on that.
Im also looking at a Kronenburg Management Systems EGT-CAN converter its not the best but perhaps the best compromise. Rang Datron today there 8 channel unit is £2500+ vat that will be a No then . They also do a 4 channel for £1500+ vat it looks like the KMS & quotes a similar spec. who pays those prices. If you have not heard they are shite or a bunch of bandits think my money will go with KMS.
#104
For my money I would tune with all port probes installed and swap them for a single probe after the exhaust, ignoring the temp offset this would still give you a pretty decent idea before melt down.
#106
Happily retired
Rod if the probes aren't going to be permanently installed do you need the CAN BUS capability? with out the Can bus accurate K type conditioning circuits become much cheaper.
This is a classic example of setting off down a path & not thinking .
We have used up 11 of our 16 Analog inputs & so decided to leave them as spare hence use CAN. Did not expect the massive price difference I have found. Ive just checked my Circuit Diagram & we still have those 5 inputs clear so indeed do I need to use the CAN Bus the answer is no .
If I used my brain I would be dangerous just needed a prod in the eye that your post gave me. Will speak to Mark about a single probe.
I can buy an amp for £128 & take a 3 week cruise in the Bahamas. Thanks for stopping my headlong rush to the CAN Bus.
The following 2 users liked this post by Rod-Tarry:
opposite lock (22-10-2015),
Rob_DOHC (28-09-2015)
#107
Happily retired
The Inconel ones are more expensive but may be worth it as they are also .3 not .25.
#108
If you do end up only using one of the inputs (ie one sensor after the turbo) you will have an extra 4 spare too Just make sure the ecu and EGT amp share a ground so that you don't end up with a ground offset voltage.
Rob,
#109
If it's just for a day or so to test, you could buy a 4 channel k type reader Rod.
Really quick google brings up things like so:
http://www.gainexpress.com/products/...sd-card-logger
If you started ECU and that reader logging at the same time you could still plot the engine speed etc against exhaust temps, and you still get the live reading to eye ball so you can abort the run if you need to
#111
Yes the cold junction compensation is worth having and should be standard on anything using a decent K type amp IC.
I would probably do as above and have an external unit... but I do agree that logging EGT via the ecu is sooo much easier when mapping than having the ball ache of different graphs in different programs all with different time stamps... I usually use a separate program for displaying logs of knock and fucking hate using more than one program on a single screen (laptop).
Better than all of this is a combustion pressure monitor... but they have their own quirks and demands. But the impact upon tuning ignition and monitoring det/missfire is out of this world.
#113
Happily retired
Ray Hall (Emtron) has recommended Exhaust Gas Technologies 4 Channel amp. Im also looking at one made by Stack which is more expensive. They all have CJC as far as I can see.
#114
theres not a lot i can say constructive other than im in awe of the engineering and technical calculations that goes into something that to the outsider is just a car designed to go extremeley quickly in a straight line. of course theres much more to it than that, man vs physics ect. its a hell of a feat to go over 200mph, i cannot wait to see what the latest build is capable of.
Rod-Tarry (30-09-2015)
#118
Innovate - 12hz no cjc. Be a waste to buy probes that can detect individual combustion events, and connect to innovate. as the information would be lost at 12hz.
Omega have a large choice of K's.
#120
Happily retired
Have gone with Ray Halls suggestion & ordered the Exhaust Gas Technologies unit & 4 stinger probes. Not the cheapest its £405 delivered.
Next the decision on the Voltage Booster.
