MA Developments Sapphire Cosworth 600+ HP 4x4
#161
wesskitzo
Yes bud unfortunately so 650bhp was on the final race cross d the line with a 7second dead!! time which gave him the win for his brakes too lock up milli seconds from crossing the line went up the bank and hit the concrete wall at a minimum of 70mph cos he crossed the line at roughly 140mph car is dead shell was twisted and squashed boot and all door shuts were out by about 5". He jumped out car within seconds and was luckily unhurt
#163
But from the video he was def not doing anywhere near 140mph and he seemed to just leave braking well too late to stop before the corner of the track. He locked up cos he broke so late before the bend and ran out of road...
This wasn't a track day (for people that ain't seen the vid)
He seemed to be just doing sprints down one of the straights
Cheers Paul
#164
There's no chance it could get upto 140mph on a 7secind run
turbotrev (20-09-2017)
#166
Was just wondering what was happening with this - any updates on car and driver?
slammedorion (19-11-2017)
#168
Good to hear
Hope well get updated here regularly
#170
Cheers Paul
#172
the new car will be on the road this spring..
Already busy for 2 months.. Bought a very mint and very low milage example a while ago and it's already stripped, meaning that all the parts on the underside are off the car and also the complete engine is out.
Zero rust, completely Original and bottom painted is painted at the moment and this will be updated shortly with some new pictures when fitting the new parts on the car
Some pictures below when visiting the car, and taking it home...
#173
Looks good
Keep the updates coming
#175
Wow what a stunning car to start the new build. I bet the phone is ringing off the hook to buy the standard parts.
#176
Itll upset the purists too
Love it
Love it
#181
Good to see your already cracking on with it all again, FairPlay buddy
Cheers Paul
Cheers Paul
#182
good news.
you obviously know what you're doing and done it before but is there anything your going to change this time? were there parts you weren't happy with on your last build.
good luck.
si.
good luck.
si.
#183
Thanks for the replies.. New update this weekend with some photos of the current activities going on
Yep change of coilovers, from GAZ Gold to Black Art Design coilovers in Mark Sheads M.A Developments spec, this will be a good improvement.
For all the other parts they stay the same and don't need changing as I was happy with them
#184
little update.. couple weeks ago I totally cleaned and degreased the underside ready for stonechip spray..
Covered the car all around and sprayed the underside which came out good
After that I finished painting the engine bay in the Ebony Black car colour which also came out good.. Most of the work will be covered by parts in the engine bay ofcourse but while everything is out it's a easy job to paint it..
#185
Well done, nice job you did there
#189
That’s exactly what I need to do to the underside of mine in the next few months, except I don’t have a ramp... ha ha
Looks pukka
Cheers Paul
Looks pukka
Cheers Paul
#190
Some steps further in the project.. Engine and gearbox is in..
Now starting to fit everything around it
Some new engine bay clips
New firewall plate from Ford new old stock
Engine and gearbox ready to go in
New BAD suspension Mark Shead spec
9" inch Ford motorsport rear diff
New bearings and studs for flange / hub
Painted fuel tank in place
#193
Car should be ready somewhere end of April I hope.. Im trying to create as much as free time possible in the weekends and sometimes in the evenings to work on the car..
I basically have all the parts needed to finish and no new engineering is needed so with every hour spend more parts are installed on the car
#196
it's already been a couple months back (time goes fast) but the car was done early Spring around end of April..
Then car alignment and back on the road to drive again.
Filled up powersteering and let the pump run so that I don't have to worry about that when the car fires up for the first time again
Clean fluid comes out of return hose so it can be connected back to reservoir-
Technically ready for first start-up
Wheel alignment done front & rear
slammedorion (10-07-2018)
#199
Oh yes
#200
Doesn't get much better than this top saph
