sapphire 2000e
sapphire 2000e
3 owners from new same family since 1995 when he paid £1500 for it, still got the receipt
it was given to his daughter in 2010 when she had her Honda civic stolen. My friends mom. she was nearly in tears last night.
Regretably it doesn't have full service history as several receipts and invoices were binned in a tidy up when she got the car from her dad. Although I do have a folder full of paper work including aprox 17 old mots
My plans are a little unclear on what to do, it is perfectly usable as is but im thinking I want to make it a minta It currently as 11 months mot and taxed end of September. But the is quite a few advisory's like tyres perishing brake pipes/hoses.
I have a few photos but not loads so I will add more of bodywork once iv given a damn good cleaning.
seats are fitted for now, not sure whether to leave black or dye grey,
poor pic I was losing light
what ya think?
i have copied this from another forum if it sounds a little odd in places.
what ya think?
Ben
Now there's something you don't see any more!
Definitely give it a good rogering and tart up, be a nice daily smoker that.
My original plan did involve a garage space but that as fell through. so its currently kept outside
The shell itself is pretty good, although it as had welding done in past to sills etc, bodywork wise as you see is very good passengers rear arch as small patch of rust aprox 40mm long and drivers blister the size of little finger nail. only other rust is by the sunroof on both side again only small maybe size of 20p coin.
It is a shame about the leather. the recaro's came up on facebook at bargain price of £150 so couldn't say no really.
I am ordering a litre of grey pigment from buffalo leather in preston and will recolour to patch original
not done a lot, but iv got the shocks front brake pipes rear disc/pads on order. Also bought some paint for the underside off a friend of my dads who deals with old tractors so I known to be very durable, same spec on that auction site is around £24 per litre. I paid £10.
Received 1,042 Likes
Looks nice that matey. I would get some cossie door cards for the interior.
Check your chassis legs underneath the rear beam when you fit your suspension springs cause you will have to drop the beam to fit these.
stu the cozzy leather is going tobe dyed grey to match rest of 2000e trim.
glen don't need the door cards because of^^ lol.
the springs are -40 mm so not that low at all. I think what glenn ment was the beam needs dropping if the chassis legs are a mess
How do you fit the springs matey.This is how ive done them on the cossie. On my old hatchback sierra i cut the bracket for the brake pipe removed the shocker bolts and leavered the rear suspension arms down.
that looks nice on the escos rims. what was the drop on that?
I'll have a good look at the rails, iv got a wire brush for my grinder so any surface rust will be attended too. treated and painted so should be good for a while.
well I managed to get a couple of hours on her on sunday, finally removed that spring, put a spring clamp on it then pulled hard.
its supposed to be -40 mm we shall see.
painted trailing arm fitted new spring and put a new disc on, its not had one on in over a month.
this looked like surface rust till I attacked with wire brush. not sure best way to address it, its the only rust on wheel arch
started to strip front off. I noticed my bumper a dropped, it appears the hole for the bracket as rusted a little.
Looking sorry for itself.
iv not said in previous posts but I have descided to replace the sills, when I attacked the inner wheel arch with wire brush(on a grinder) I found filler on a previous inner sill repair. So gona cut out the sill and sort that out.......
bumpstop had collapsed on this side. people keep saying they never had an issue removing it, but il be honest found it an ar*e of a job. Im new to fixing fords...
if you look at 1st pic I posted tonight stu, the white mush used to be the bumpstop[. the steel cone and rubber around spring itself makes it a bugger too.
I'd love to swap my rear springs for something a little higher, (just really for cosmetic reasons) but always put off thinking it was a total pain in the arse!? As you say, it's the metal part the stop sits on....
I've had an 1/2 descent afternoon on her.
all the crap as been cut out tidied up, new sill trimmed, no point fitting the full 1 as would be harder to hide without proper paint job, no confident enough to do that.
Inner sill repaired wasn't that bad to be fair only took a strip about 200 mm long and 40mm deep. me being dumb I didn't take pics of this. So as it stands now the sill as been fitted and seem sealed, i didn't want filler in the sill so that was sealed to. not sure was my best option?? Anyhow a few pics.
I know i will need some filler to wear the lip as been repaired but it will only only need a bit i think.
