Where to buy sapphire / 5 door inner repair arches?
Hi,
I'm trying to sort out the usual rotten rear arch problems on my sapphire and can not get hold of the inner arch repair panels. Ebay lists inner arches for a 3 door but not a 5 door / sapphire and according to panel suppliers websites they are different part numbers. I've purchased the outers and I have a 3 door inner that I tried against the outer and its close but where the sapphire has a thin bit where the door aperture goes the inner and outer touches when held together. Does anybody no where I can get Sapphire inner arches from? or what you've used when doing your own? Thanks. |
Some people buy a rear repair arch and use that for the inner arch.
You cant buy the inner only the outer, most use the outer arch to repair the inner arch as there isnt really much other choice. There available from euro car parts and are dirt cheap
I got mine form motomobil
Thanks for the info guys.
Originally Posted by Matt Baxter
(Post 6477146)
Cheers. |
Car Parts Express have the o/s one in stock - usually have both side in stock & only something like £35. Give G a shout an he will sort you out.
Thank you.
Will do if required. |
You can still get them, I had one replaced on my saph only a month ago.
© 2024 MH Sub I, LLC dba Internet Brands
