Zetec turbo
Zetec turbo
Guys in getting a 2.0 Zetec built for more boost, aiming for about 400ish bhp plus nitrous, what gearboxes and axles are you all using for this sort of power? Guessing I may have to go T5 with an atlas or 9"
I'm using a T5 gearbox and Volvo rear axle. An Atlas will do but it needs heavily (and costly) uprating or an 8-inch Ford axle is sutiable but they are getting very rare and the ratios aren't usually ideal for a four-cylinder turbo. A 9-inch is a bit overkill. You will need a dry sump at that kind of power by the way.
my capri just runs a standard mt75 and 2.8 atlas and limo and 215/45/15 toyo proxies with about 290 bhp haven't broke anything yet
Why do zetec's need dry sumping above 400bhp thought it was revs that killed the oil pumps ??
It's going in my ford Anglia, I'm already running a supercharged 1800 Zetec but just need more power, I've heard it's a combo between revs and the extra force the boost is putting down on the crank?
