PassionFord - Ford Focus, Escort & RS Forum Discussion (https://passionford.com/forum/index.php)
-   Restorations, Rebuilds & Projects. (https://passionford.com/forum/restorations-rebuilds-and-projects-29/)
-   -   Jay's MK2 Xr2 Project (https://passionford.com/forum/restorations-rebuilds-and-projects/460727-jays-mk2-xr2-project.html)
xr2mk2turbo Sep 24, 2013 12:34 PM
3 Attachment(s)
Right ladies and gents project thread time, My names Jay and the car in question is an early spec MK2 Xr2. I bought the car in January 2009 on a whim basically. I had one 10-12 years ago and she was so rotten I had to scrap her, not having any way of restoring her, so to make up for my sins I bought this one.
The story behind this car was one day in Jan 09 I had a thought, I would really like a mk2 xr2 again, it must be red and early spec, so to ebay I went, and the only one was about 30 mile away and ending in about 5 min... so I bid and won, then the moment of realisation, no research, not seen and no idea what the going rate was, turns out she was a bit of a bargain(bearing in mind the missus had no idea) Picked the car up the day after in secret and tucked her in the garage.
When I got the car it had a fresh MOT and Tax and had been laid up for a long time. The side skirts were gloss black and for some reason the wrong back tyres.
Attachment 80638Attachment 80639Attachment 80640
xr2mk2turbo Sep 24, 2013 12:52 PM
Now I’ve been beavering away for a while now and I must give absolute credit to my missus as when this car turned up she knew exactly what the next umpteen years meant. No spare cash car parts everywhere, all my clothes ruined, manky hands permanently and finding random parts in the dishwasher, oh and a lot of road trips up and down the country.
Initial plans for the car were to track car it starting with a ERST engine as I always wanted a turbo one, anyway after doing the conversion and running it for a while I changed my plans and decided to go standard, original and clean. Boy there funTurbocharged, being such a light car the boost feels very aggressive
xr2mk2turbo Sep 24, 2013 01:39 PM
1 Attachment(s)
First up rear running gear:cry:
Attachment 80637
xr2mk2turbo Sep 24, 2013 01:56 PM
9 Attachment(s)
Attachment 80628
Attachment 80629
Attachment 80630
Attachment 80631
Attachment 80632
Attachment 80633
Attachment 80634
Attachment 80635
Attachment 80636
xr2mk2turbo Sep 24, 2013 01:58 PM
Pictures will be better soon on, old phone pics:sad:
SBT83 Sep 24, 2013 01:58 PM
Looks good dude! :top::top:
xr2mk2turbo Sep 24, 2013 02:00 PM
3 Attachment(s)
Attachment 80625
Attachment 80626
Attachment 80627
xr2mk2turbo Sep 24, 2013 02:06 PM
2 Attachment(s)
Next up was to heat proof lacquer the rear brake parts, to stop rust and easy cleaning
Attachment 80623
Made some gaskets to go between Drum back plates and axle, 0.5mm industrial rubber
Attachment 80624
xr2mk2turbo Sep 24, 2013 02:37 PM
4 Attachment(s)
Attachment 80619
Attachment 80620
Attachment 80621
Attachment 80622
xr2mk2turbo Sep 24, 2013 02:46 PM
2 Attachment(s)
:grin:
Attachment 80617
Attachment 80618
xr2mk2turbo Sep 24, 2013 02:48 PM
Cheers pal
Matt Evans Sep 24, 2013 03:02 PM
Attention to detail like that is always worth seeing!
Matty B898 Sep 24, 2013 05:24 PM
Top work. Keep the updates coming.
Fordmad! Sep 24, 2013 05:51 PM
Top work pal, keep pics coming!
Only 5 mins down the road from me!
Nice GTE btw
Wood5tock Sep 24, 2013 06:31 PM
Love the finish you've got on the running gear
Mmm... Standardgasm :top: :top: :top:
Keep up the great work
XR2 Sep 24, 2013 06:54 PM
Very, very nice. When you keep up this kind of work, this will be better than it left the factory!
:top: :top: :top: :top: :top:
Glenn_ Sep 24, 2013 10:15 PM
Very cool.Nice car.Keep up the good work.
xr2mk2turbo Sep 25, 2013 08:39 AM
6 Attachment(s)
Thanks for the comments guys, appreciated. the Nova's not mine, my cousins LET and he lives right by you. Found a couple of anti roll bar pics...
Next up anti roll bar, the one in the picture below is the one I bought to do off the car to make life a little easier, before and after...
Attachment 80543
Attachment 80544
Attachment 80545
Attachment 80546
Attachment 80547
Attachment 80548
Wood5tock Sep 25, 2013 09:22 AM
What process do you use to get the stuff so smooth before painting, and what paint have you been using? Looks so good :drool: :drool: :drool: :top:
xr2mk2turbo Sep 25, 2013 09:49 AM
The rear roll bar was sand blasted first, the axle was done by hand..Never again :cry:. Generally I spend a lot of time on the prep of the metal work with small files and emery paper as the axle for example was covered in factory weld splatters and factory marks, so I spent time filing the weld splatters and shaping all the welds etc, all faces and flat edges of brackets etc were filed and re shaped as they were rough from factory. Several coats of U-pol etch primer followed by maybe 4-6 coates of Mipa high build primer (really good stuff very tough and easy flat back and cheap) and then flat it back so the imperfections of themetal are just showing through underneath, then one more good coat of high build, a light flat off then 3-5 medium coats of satin black, used Halfrauds satin black for the running gear simply because I can get it easily so it all matches in the end, and can be touched up easy in the future
xr2mk2turbo Sep 25, 2013 01:19 PM
4 Attachment(s)
Next up rear brake compensator thingies:grin:
Attachment 80532
Attachment 80533
Attachment 80534
Attachment 80535
Fordmad! Sep 25, 2013 03:09 PM
Dont think ive seen the nova around tbh
bigryrs Sep 25, 2013 03:20 PM
Nice work mate :) keep it up
xr2mk2turbo Sep 25, 2013 03:26 PM
Not been on the road for 12-18 months tucked up in the garage, using his bike at the moment, also had a red GTE and another white GTE, so you might have seen him in one of them, Wrexham has always had a big nova following, see loads of nice ones about here, also seen a Satin red Cav Turbo and two saph Cossies in the last few weeks
xr2mk2turbo Sep 25, 2013 03:29 PM
Cheers pal, hope to.
CrOwSoN15 Sep 25, 2013 04:44 PM
Very nice, excellent work on the running gear too!
xr2mk2turbo Sep 26, 2013 10:06 AM
11 Attachment(s)
Next up Panhard rod and rear trailing arms, found a new Panhard but wasn't happy with the Finnish so filed all edges and gotrid of the weld splatter, shaped welds and painted it up. The Trailing arms were new and stripped back to re-paint. Whilst I had them stripped I filled in all the voids to stiffen them up, and then shaved excess with stanley blade. Also had a new Panhard rod Sticker made up.:grin:
Attachment 80447
Attachment 80448
Attachment 80449
Attachment 80450
Attachment 80451
Attachment 80452
Attachment 80453
Attachment 80454
Attachment 80455
Attachment 80456
Attachment 80457
xr2mk2turbo Sep 27, 2013 09:13 AM
1 Attachment(s)
Finally got a top tint Screen. :banana:
Attachment 80365
Wood5tock Sep 27, 2013 04:59 PM
Awesome attention to detail mate, and thanks for the info on the paint you have been using :grin:
BLU Sep 27, 2013 05:09 PM
Good work so far. Not too far from me either :king:
xr2mk2turbo Sep 30, 2013 08:21 AM
Cheers Pal, where are you?
xr2mk2turbo Sep 30, 2013 08:36 AM
9 Attachment(s)
Fan and housing sorted, housing was blasted, repaired (rust) painted in an epoxy high gloss high temp paint, chuffed how it came out, fan painted with VHT aluminium Paint
Attachment 79912
Attachment 79913
Attachment 79914
Attachment 79915
Attachment 79916
Attachment 79917
Attachment 79918
Attachment 79919
Attachment 79920
xr2mk2turbo Sep 30, 2013 09:57 AM
1 Attachment(s)
Cool Retro Alarm, im going to wire up to modern system I think.
Attachment 79910
BLU Sep 30, 2013 01:27 PM
Holywell.
Good work on the fan :top:
xr2mk2turbo Sep 30, 2013 01:32 PM
Cheers pal, no your not far from me, lol just replied to you in another thread, Fail on my part:oops:, how you getting on with your car?
BLU Sep 30, 2013 01:35 PM
Yeah just seen that reply! :DD:
Been quite slow. Hoping to crack on with it and get it painted in the next few weeks before the cold weather sets in!!
xr2mk2turbo Sep 30, 2013 01:41 PM
Yeh happy days, need to get it done before it goes cold, also it isn't fun working on them when its cold, Im going to do the wheels over the winter in the spare room, and hit the car again in the spring.
BLU Sep 30, 2013 01:57 PM
Thats a good idea!!!
I have no spare rooms do do that as they're all taken up by my kids...... :roll: :lmao:
Wood5tock Oct 1, 2013 12:09 PM
Once again well impressed with the level of finish you are getting on all the parts you are restoring. It's like NOS when you have finished, in fact better :top: :top: :top:
xr2mk2turbo Oct 1, 2013 02:49 PM
Cheers pal, trying my best to do it right
why didn't I just build a track car like originally planned:cry::cry::cry::cry:
© 2026 MH Sub I, LLC dba Internet Brands
