Zetec turbo blue Orion 400 bhp aim UPDATE now running 03/10/13
#81
Well struggled to get much done today as had problems with the welder. But i managed to get the manifolds and turbo bolted up and i started makeing the downpipe or atleast cut the bends ready to tack in place also adjusted where the the coilpacks will sit also took measurements and made a list of things i need to order its a little tight in there and am going to struggle with the airfilter etc but hopefully should all work out central day is not looking hopefull at the mo :-(
And lol
And lol
#86
Managed to get a few bits done yesterday and going to do some more today also some new bits and pieces have arrived.
Dean fitted my injectors fuel fittings a fuel pipe.
More R888's arrived.
Ajc playing with the welder.
#87
Downpipe made just need to add a flexi.
Not the best but made out of old pipe will do the job.
And my 90 bend came when i got home so first job today is to make my screamer pipe
#91
Did a couple more hours on it today.
Screamer pipe
Thinking of getting another 90 bend and bringing the screamer out in front of wheel or out the front bumper to keep any heat away from the box.
Fuel pipes fitted with new fixings.
Screamer pipe
#103
Ah found it at last.
Sorry itd been a while but we decided it wasnt going to make central day so i downed tools on the onion.
Then i had to pick up the welder and spend rather a few weekends welding up my poor old discovery but the old girls all sorted now
So now i am back on with the onion not sure when it will be finished as i am haveing a few issues getting it mapped.
Updates soon.
Updates soon.
#105
As for inlet price you would have to speak to crazycage on here as i dont want to disclose his prices and i have no clue as to the rover inlets and thanks for the compliments
#109
I have not got alot done lately, what had been done is fiddly little stuff and ordering bits.
Heres ome pics of of stuff thats arrived.
#110
#116
Went and did a little tonight.
I got the lambda boss welded in
Also we have been having trouble with the rear housing of the turbo to v band flange as we couldnt get an m8 bolt in m6 obviously too small. We was going to tap the exhaust housing to put studs on but the holes are to big so woul have to use m10 which would be to big.
So i have ended up using threaded bar to the lenght need put then welded the nuts in place on the back not the best but it works
#120
Thanks for the compliments.
rsmark86 the spec was 2.1 zetec turbo, efi inlet, 750cc injectors, standard exhaust manifold with a T34 turbo 0.48 rear housing, standard head and cams but with double valve springs, pro alloy front mount cooler, it was on megasquirt management running only a base map at 18-20 psi, cts stage 2 quiffe gearbox, and R888 tyres.
Spec as you can see was very simple and had alot more to give had we have fully mapped it.
After that we changed the exhaust manifold to my previous over the gearbox one. put a grs cooler on and went back to ofab managenent with a plug and play chip and big beige injectors as had issues with the megasquirt.
At this set up went back to pod bbut had various issues and only did 3 runs as my clutch cable snapped but i did a 12.8 run again this would have been alot better but various probs stopped us running.
Hope this info helps.
