"Roxanne", Red Mk5 Zetec S Project
#82
Updates on my progress
Nearly at the point of putting her back together, just finishing the floor plan. Couldn't start it till it got a little warmer than -1℃ and had to find a generator to loan.
Anyway, pics
Said generator
Subframe off (after a bolt snaps Grrr), and it'll be cleaned up, polys added to the arb whilst at home
My floor, this is not as bad as it looks. 3 years of sitting outside has caused this.
Fuel lines off
Angle grinder time
Then these plus stone chip to be put on.
I managed to get the epoxy onto the areas I've got down to bare metal today. Once dry I'll be putting the stone chip over it all, then a top coat.
Rear being stripped
First hole, whoops
Painted
Arches got same treatment
Front seam sealer
Then etch primer
Then stone guard
Front arb bushes came
Both front wings are in the final product, colour!
Floor had the rest of the stages as the epoxy takes a while to dry/harden
Etch grey Primer for the floor up to the fuel tank
Then in the white stone guard
Rest of the bay went into primer then Stone guard
Colour will be added to those areas tomorrow, and I'll see what else I can get done
Anyway, pics
Said generator
Fuel lines off
Angle grinder time
Rear being stripped
First hole, whoops
Painted
Front seam sealer
Then etch primer
Then stone guard
#85
Looking good
#87
Nice job It's a big task done on the floor but worth the effort in the end
Keep the pics coming
#88
Cheers!
Yea it really is. I'd rather do it properly than not do it at all. And after spending so much elsewhere, it was a bit of a guilt trip lol
#89
More updates
SHE'S FINALLY HOME!!!And we got stuck in straight away
Flatbed home
Front windows in,rubbers cleaned up and refitted, mirrors and door handles fitted
First time I've seen the painted bay in the sunshine :wub:
Cleaned up the rear disc conversion, before:
After
Fitted rear disc conversion
How wide the rear sits with a rear disc conversion and frk's
St150 handbrake cable plumbed in as neat as possible
Dash came out
So did the loom
Fresh paint loving
Euro lights fitted with all new bulbs
New interior loom fitted and dash back in
Boot internals installed, wiper,handle and locks too
AC pipes polished up and refitted along with other bay bits
She's starting to come together nicely now.
Flatbed home
After
Dash came out
So did the loom
Fresh paint loving
#97
Rear disc conversion being painted?
It's all looking good though
#98
Welsh Animal (26-04-2017)
#100
Updates
Sorry it's been a while, had my head down and I've been cracking on.
Ghia washer bottle fitted:
New bonnet "sponges" on
Ford racing gel badge
Custom stickers thanks to Alex!
Centre caps were looking tired, so bought some off Alex
Before
After
Frk's got powder coated
New frk/frp wheel nuts and locking nuts
Tyres and nuts trial with some new rubber
Before and after
220mm focus 1.8 clutch and fiesta slave
Cambelt kit
Took the engine to have the cams fitted and timed up
checking cam clearances, needed smaller shims
New shims from lms
Engine put back together
Subframe powder coated and poly bushed arb
That shine!
Fitted
Engine went in too
Fuel lines and brake pipes fitted
Mondeo mk3 servo painted
The last set of bonnet gas struts bought
Fuel tank cleaned and painted
Filler neck cleaned
Interior...
Bought these frp seats years ago for Ł80 only because of what I want to do to them
Set about replacing parts
Off to the retrimmer
Including New steering wheel
And I pick them up this Saturday..
Plenty more updates to come. Won't take long to put her back together now!
Before
After
Before and after
Cambelt kit
New shims from lms
That shine!
Fitted
Engine went in too
Filler neck cleaned
Interior...
#101
Brilliant work well done. You must be chuffed with your work?
#102
Thanks!
I wouldn't say chuffed as I'm quite picky but I am happy. I don't just "settle" for things lol. I'm shocked at my determination and what I've learnt, as I'm not a qualified mechanic or anything so at this stage I'm having to read up about a lot of things and learn how to do it. Glad to see these long awaited plans happen!
#103
Interior collected Friday night. The guy has done a perfect job with the seats. They are absolutely spot on! Not going to upload a picture of them anywhere until they're in the car. But here's a tiny preview with the steering wheel.
#107
Yes mate but photobucket has stopped image sharing so not updated anywhere. She is complete, just need to fit the interior and give her a good clean for Ford fair.
Rsmat (04-08-2017)
#118
