MkI Fiesta conversion question.
I am new here so hope this is correct area to post.
I am in the process of building a MkI Fiesta with 2.0 Zetec engine and would like some advice on suspension choices I should go with front and rear. Any advice is welcome :) |
not fully sure what you mean with "should go with front and rear"
Are you after brands people are using or what? Rear can't use coilovers unless adapted for them, i run a Gaz Gold kit on mine, they supply a fixed kit for the rear and coilover for the front |
Sorry I did not make it clear what I meant.
Was looking for manufacturer and part numbers if possible, for both front and rear. |
Dunno on numbers, i just called Gaz. Told them what i had, what i was running, the intended use for the car and they specced the springs accordingly. Avo have options too.
Thank you.
© 2024 MH Sub I, LLC dba Internet Brands
